924, 944 door chime silencer
944er
Has thanked: 13 times
Been thanked: 53 times
Sometimes I'm working on something with the door open and ignition on and the dang door chime just keeps on dinging. I know on the later cars it is easy to just pull it, but on the early cars you have to remove the auxiliary fuse panel. This, admittedly slightly silly device, fits over the switch and slips past the inner metal panel of the door where it locks into place, holding the switch in. I suggest a using a bright color so you don't forget it when you go to close the door.
Has thanked: 4436 times
Been thanked: 2411 times
944er wrote: Sun Jul 21, 2024 12:14 pm Sometimes I'm working on something with the door open and ignition on and the dang door chime just keeps on dinging. I know on the later cars it is easy to just pull it, but on the early cars you have to remove the auxiliary fuse panel. This, admittedly slightly silly device, fits over the switch and slips past the inner metal panel of the door where it locks into place, holding the switch in. I suggest a using a bright color so you don't forget it when you go to close the door.
Brilliant - I love it!
