924, 944 door chime silencer
Sometimes I'm working on something with the door open and ignition on and the dang door chime just keeps on dinging. I know on the later cars it is easy to just pull it, but on the early cars you have to remove the auxiliary fuse panel. This, admittedly slightly silly device, fits over the switch and slips past the inner metal panel of the door where it locks into place, holding the switch in. I suggest a using a bright color so you don't forget it when you go to close the door.
- Has thanked: 4467 times
- Been thanked: 2428 times
Brilliant - I love it!944er wrote: Sun Jul 21, 2024 12:14 pm Sometimes I'm working on something with the door open and ignition on and the dang door chime just keeps on dinging. I know on the later cars it is easy to just pull it, but on the early cars you have to remove the auxiliary fuse panel. This, admittedly slightly silly device, fits over the switch and slips past the inner metal panel of the door where it locks into place, holding the switch in. I suggest a using a bright color so you don't forget it when you go to close the door.
