Can these connectors be depinned?
V951S
Has thanked: 36 times
Been thanked: 14 times
Bought new rubber grommet/sleeves for these headlight wiring plugs.
I was hoping that the connectors can be depinned so I could pull the individual wires through the new sleeve.
Does anyone know if it can be done with these connectors? I need to either purchase or borrow a set of tools to try it.
'88 944 Turbo S
Been thanked: 4081 times
Let me see if I have an old one I can operate on. Are they the same as the O2 sensor connector? Suppose you could always hide solder joints under the sleeve?
V951S
Thanks Tom - it looks like the same type of connector as the O2 sensor.
Cutting and soldering might work if I had to... Ideally, I'd like to keep it as original as possible and not have to cut any wiring. I'm avoiding hacks if I can help it, even the hidden ones.
'88 944 Turbo S
V951S wrote: Thu Aug 14, 2025 8:55 am Thanks Tom - it looks like the same type of connector as the O2 sensor.
I'm with you, let me investigate on some old harnesses....
V951S
Hey @Tom - I just found this video online. Looks like they can and he even lists the depinning tool size:
(Sorry to post a question and answer it myself - just kept digging around in parallel.
'88 944 Turbo S
Awesome, you saved a spare connector. :lol: No apologies needed at all! Way better than posting a question, figuring out the answer, and then not sharing the answer!
Zirconocene
Has thanked: 79 times
Been thanked: 51 times
I'll take a look at that video, that seems like a good find. Those SureSeal (from ITT Cannon) connectors are not expensive but the tools to service them are hideously expensive.
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
Zirconocene wrote: Wed Aug 20, 2025 10:52 pm I'll take a look at that video, that seems like a good find. Those SureSeal (from ITT Cannon) connectors are not expensive but the tools to service them are hideously expensive.
Happen to have a link to the extractor tool? Wondering if it could be replicated on the cheap...
gb951
Has thanked: 28 times
Been thanked: 37 times
[/quote]
[/quote]
Found these:
https://www.amazon.com/dp/B0972DD5N1
V951S
@gb951 - Those are the ones I ordered, but I got them directly from the company and paid an extra $10 for shipping. Ugh. They are expected to arrive today.
I was able to remove the male pins with a tool I borrowed from a neighbor. The females ones don't fit the borrowed tool.
Will try those and post an update once I get the delivery.
'88 944 Turbo S
