Oil brand recommendation
Including Spyders & GT4s
icb
Has thanked: 59 times
Been thanked: 54 times
cavediver32043 wrote: Thu Sep 05, 2024 7:23 am Lokasil and alusil blocks need Molybdenum; a friction modifier to minimize silicon migration out of the cylinders over time which is a big contributor for bore score. 4 years ago I switched from LiquiMoly 5W-40 to Driven DT40 5W-40 Oil. 07CS Manual 52K mi. I pull a UOA sample on my Oil /filter changes and Molybdenum element PPM's with LiquiMoly ran 97 ppm's. With Driven oil Molybdenum ppm's increased to 427 ppm's. Proof is in the numbers.....
I had the same experience. DT40 is expensive but worth it.
Ian Borg
1988 Porsche 944S
jack911s
Has thanked: 24 times
Been thanked: 17 times
I use Porsche Classic Motor oil, specially formulated by Porsche for Air Cooled 3.0L and above.
My 911 told me she loves it !
NormGarr87
Has thanked: 9 times
Been thanked: 5 times
I have an 03S and use DT-40 5W/40. I do an oil sample with each yearly change and the numbers look great. I purchased the car in 2017.
Current Fleet
2003 Porsche Boxster S
2024 VW Tiguan R-Line
1981 VW Pickup
1973 VW Thing - long term project
1970 VW Karmann Ghia
996C438
Been thanked: 283 times
DT40 is an oil that was invented via collaboration between Jake Raby/Charles Navarro/Lake Speed Jr . Somewhere in that mix Joe Gibbs Racing was involved . Some would consider it a boutique oil but it was specifically designed for the 986/996/987/997 series of engines .
NormGarr87
My two cents. I run Driven DT 40 in my 03S. The PO used it so I continued. I have owned my Boxster for 7 years now and all my oil reports have been spot on. My Boxster is a limited use fun machine for the street. I do not track but I REALLY enjoy the NC mountains.
Current Fleet
1981 VW Pickup
cgfen
We all have favorites, but for your use case, nearly any major brand will work well, just change it every 18 months or less.
Enjoy!
zooklm1
Has thanked: 21 times
Been thanked: 61 times
It might not be a great comparison but in my 968 and 944 turbo I use Valvoline VR1 20-50 racing oil and add a bottle of Liquid Moly Hydraulic Lifter Additive for the 944 Turbo to quiet the lifters. I started using the VR1 years ago when my turbo started using/burning a quart of every 500 miles. When I changed to VR1, oil consumption dropped to the nominal leakage around the oil pan gasket. I had initially thought the turbo oil seals were starting to fail. Answers on several forums suggested to try VR1. VR1 has a higher zinc content than most big name oils but not sure how it compares to the specialty brands.
Been thanked: 4078 times
zooklm1 wrote: Tue Jul 29, 2025 7:42 pm It might not be a great comparison but in my 968 and 944 turbo I use Valvoline VR1 20-50 racing oil and add a bottle of Liquid Moly Hydraulic Lifter Additive for the 944 Turbo to quiet the lifters. I started using the VR1 years ago when my turbo started using/burning a quart of every 500 miles. When I changed to VR1, oil consumption dropped to the nominal leakage around the oil pan gasket. I had initially thought the turbo oil seals were starting to fail. Answers on several forums suggested to try VR1. VR1 has a higher zinc content than most big name oils but not sure how it compares to the specialty brands.
Any reason you picked Liquid Molly over a ZDDP/zinc additive?
#18
zooklm1
Not really. Would more ZDDP help reduce the lifter noise? Any recommendations?
Lee
#19
zooklm1 wrote: Tue Jul 29, 2025 8:30 pm Not really. Would more ZDDP help reduce the lifter noise? Any recommendations?
Lee
In theory, but I was intrigued by your comment about liquid Molly...
#20
