Bosch harness boots
gruhsy
Has thanked: 48 times
Been thanked: 81 times
Anyone find a good source for the rubber boots on the tps sensor and afm for our harness?
gruhsy
Darwin
Has thanked: 116 times
Been thanked: 74 times
You can also source them from Prowire-USA.
2012 VW Tiguan - Kinda stock
gruhsy
Awesome thanks
Google really sucks lately
Everything that comes up searching is from China or unrelated products
Darwin
gruhsy wrote: Mon May 30, 2022 8:59 pm Awesome thanks
IDK what delay customs would cause going up to Canada, but Prowire gets their shipments out blindingly fast, usually same day. They also actually answer the phones! They also stock a lot of shrink tube, heat shrink boots, wire, connector kits, and connector parts. They’re fantastic
AudiSport
Has thanked: 6 times
Been thanked: 68 times
Do you need the whole connector? Or just the boot? The TPS is a 6 position connector. Hard to find. Check the other thread here about Junior Timer connectors, there's part numbers for just the boots. The 6 pos connector though I've only found via 944online, also mentioned in that thread.
Zirconocene
Has thanked: 78 times
Been thanked: 48 times
Back when I was making a new harness for my S2, I had a really difficult time finding a 90 degree boot for the 2 pin JPT connector. This is a nice thing to have for the injectors which have an immediate turn toward the firewall for the wiring, just off the injector. Anyway, the only place I really found that offered these was Low Doller Motorsports (no affiliation, and that spelling is correct for the vendor!). Not really what you're looking for but it may be helpful to you for other work.
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
Darwin
AudiSport wrote: Tue May 31, 2022 8:22 am Do you need the whole connector? Or just the boot? The TPS is a 6 position connector. Hard to find. Check the other thread here about Junior Timer connectors, there's part numbers for just the boots. The 6 pos connector though I've only found via 944online, also mentioned in that thread.
They appear to be readily available in Australia…lol
gruhsy
Thanks.
I thought I had read something recently.
Been reading so much stuff lately car related and work related my memory is overstuffed.
Has thanked: 945 times
Been thanked: 4040 times
Hmmmm....... this suddenly became less hypothetical to me. :( @gruhsy did you ever find the boot at a reasonable price? I really don't want to pay for the whole connector kit just to get the boot unless I really have to... or maybe I need to just print one in Ninjaflex....?
