instrument cluster warning lights
blade7
Has thanked: 25 times
Been thanked: 22 times
The main beam warning light is very dim and the indicator warning light isn't showing. What type of bulbs do I need to buy for replacements. And while I'm in there are there other bulbs I should replace?
Has thanked: 933 times
Been thanked: 4000 times
blade7 wrote: Wed May 13, 2026 11:42 am The main beam warning light is very dim and the indicator warning light isn't showing. What type of bulbs do I need to buy for replacements. And while I'm in there are there other bulbs I should replace?
https://944online.com/dash-instrument-l ... 5-2-to-95/
blade7
Tom wrote: Wed May 13, 2026 8:05 pm
Thanks Tom,
The only kits I've found over here are LED's for around double the price. Shipping to the UK would be $28, seems a lot for an medium size envelope.
blade7 wrote: Wed May 13, 2026 9:32 pm
Thanks Tom,
Shipping costs have increased dramatically lately, especially internationally. So yes, it's a lot, but it's par for the course these days!
Wespa
Been thanked: 20 times
Leds are the way to go, and be sure to check out edredas' guide on how to refurbish the cluster backlight reflectors:
944 NA ROW -86
blade7
Wespa wrote: Thu May 14, 2026 8:58 am Leds are the way to go, and be sure to check out edredas' guide on how to refurbish the cluster backlight reflectors:
I did the reflector foil refurb, and the backlighting has improved. Changed to LED's too, but still no indicator warning light, or the big red warning light above it :( . I'm wondering if the fault is in the cluster, or the wiring to it.
PSU_Crash
Has thanked: 185 times
Been thanked: 110 times
Drove my car at night for the first time a few weeks back and realized I can't see ANY of the cluster!
Strategically held my phone to see my speed.
This is also on my list. I've had the cluster out a dozen times in the past year. What's one more :D
I'll get out my spare cluster this week and see if I can find the ribbon pins needed to test the various lights -- so at least you'll know if it's in the cluster or the wiring/switches feeding the cluster...
fasterfaster
Has thanked: 160 times
Been thanked: 21 times
blade7 wrote: Wed May 27, 2026 3:48 pm I did the reflector foil refurb, and the backlighting has improved. Changed to LED's too, but still no indicator warning light, or the big red warning light above it :( . I'm wondering if the fault is in the cluster, or the wiring to it.
The LEDs are often a bit of a loose fit. Check to make sure those two are snug. I found I had to clock some of mine an 1/8 turn counter clockwise to snug them up and make good contact, or swap in a different bulb and base.
Marc
88.5 951 M030 Red on Black
