As shown here, this is the code I used to bench test and calibrate the '85.5 and later 944 tachometers. The simulated ignition pulse is generated on pin 13 of the Arduino, which can be connected directly to the pulse input on the tachometer.
944 Tach Arduino Code
- Has thanked: 935 times
- Been thanked: 4006 times
