951 TunerPro BIN & XDF Files
See full DIY Chip discussion here.
--------------Factory Chip BINs---------------
24PIN_86DME.BIN
28PIN_88SDME.BIN
28_PIN_89DME.BIN
86KLR.BIN
89KLR.BIN
----------------Modified BINs-----------------
See Terms of Service. Use at your own risk, for non-commercial use only. :angel:
24PIN_DME_PERFORMANCE.BIN
28PIN_DME_PERFORMANCE.BIN
KLR_NO_OVERBOOST.BIN
--------------TunerPro XDF Files---------------------
XDF updated to Version 3 on Oct 3, 2025, to include ignition dwell tables showing in both raw BIN values and in calculated Milliseconds.
Carpokes24PinV3.xdf
Carpokes28PinV3.xdf
whalenlg
Has thanked: 8 times
Been thanked: 119 times
Hi Tom - I don't see the .XDF files here...CarpokesPublicV1.xdf?
1986 951 - Silicon Valley
whalenlg wrote: Wed Sep 24, 2025 10:58 pm Hi Tom - I don't see the .XDF files here...CarpokesPublicV1.xdf?
Oops. Just added them. :shifty:
clement-931-951
Hello, Tom thanks for all those precious information.
I have few question about the files that you share:
-Are all the files with KLR for the secondary ecu/eprom ?
-Are all the files for 951 but depends on production date?
-Can we manage to run on E85 and replace the AFM sensor for a MAF with tunerpro and a tuned ecu?
clement-931-951 wrote: Wed May 13, 2026 9:34 am Hello, Tom thanks for all those precious information.
Re KLR files, if I understand your question, yes. There are two ECU boxes in the footwell of the 944 Turbo. The one on the left is called the DME and the one on the right is called the KLR. The files with KLR in their name are for that box on the right -- the KLR box.
The 951 files are not based on production date per se. They are based on whether your DME has a 24-pin chip or a 28-pin chip and whether your car is a normal turbo or a 944 Turbo S (which includes 1989 951's for this purpose).
You can edit the maps to provide the correct amount of fuel for E85. I would do that by adjusting the FQS value to supply 30% more fuel across the board, then fine-tune the actual maps as needed from there.
MAFs have a different output curve than the AFM so it is more of a challenge to edit the maps, but there are many examples of people running MAFs with tuned chips, so very possible. The XDF files include the transfer function maps to better map the chip to the output curve of your MAF, but that is an advanced technique. Running a MAF with stock/tuned chip is always a bit of a compromise, which is why Vitesse Racing and later Rogue Tuning rewrite the code for their MAF kits to better read the native MAF values. Doing that is not possible with these tools. But bottom line, yes, you can edit chips to use a MAF, but the tune may never be as good as an AFM tune.
944m3
Has thanked: 28 times
Been thanked: 111 times
Shameless plug. I have a Vitesse MAF chip I’m not using. This would only be the chips. Make me an offer if interested.
944m3 wrote: Wed May 13, 2026 5:55 pm Shameless plug. I have a Vitesse MAF chip I’m not using. This would only be the chips. Make me an offer if interested.
Vitesse replaced the chip with his Chip Board -- i.e., a circuit board that plugs into the chip socket. Is that what you have?
944m3
Tom wrote: Wed May 13, 2026 6:07 pm
Yes. I’m using the snorkel with my standalone and plan to maybe use the MAF sensor.
944m3 wrote: Wed May 13, 2026 7:03 pm
You might just pick up a generic MAF since you'll be tuning to it yourself either way? (Or use a map sensor.) The parts in the Vitesse MAF kit are worth more together than the sum of their parts I'd say...
944m3
I had the whole kit posted for sale and wasn’t getting any bites. So just kept the snorkel on the car.
That being said, i have thought about 3D scanning it and sending it out to print. Surprised I haven’t seen it offered somewhere.
