944 Under Radio Panel
- Has thanked: 943 times
- Been thanked: 4032 times
Here is a blank panel to go under the radio on an 85.5+ 944. I'll post variations with gauge holes in due course. Note the stand-offs in the bottom corners, which prevent the panel from slanting in at the bottom like most flat panels do. The little notches are there to prevent the panel from riding up on little tabs in that location on the car. The little wall at the bottom helps give the bottom of the panel more strength, so it doesn't flex in as much when touched. Subtle differences, but they make for a better panel.
