Fuel Rail Woes
EuroFighter2003
Has thanked: 20 times
Well, I wanted a project car and I got one :lol: . Was replacing the fuel lines and fuel damper line and ended up bending the fuel rail while attempting to remove the large nut holding the fuel damper to the rail. I was planning at replacing the fuel rail at some point...might as well do it now.
Does anyone have any opinions/suggestions on aftermarket rails? Looks like the two options available at the moment are lindsey racing and nuke performance. My main concern is that I have already purchased and half-installed the fuel line kit from rennbay and don't know if the hose fittings from my rennbay lines will be able to be used with either of these options.
Additionally, I could consider going with a used 944 rail (for considerably cheaper), but don't know if it would be worth the risk of going through the same problems I am having with my current rail.
Any feedback would be greatly appreciated!
Evan
Has thanked: 10 times
Been thanked: 20 times
Go with the Lindsey Racing or Nuke rail if you want reliability and better performance just double-check fitting compatibility with your Rennbay lines. A used 944 rail is cheaper but risks the same issues you’re dealing with now. Not worth the hassle unless you’re on a tight budget.
