Upgraded my FPR so now I have a BBM adapter and AFPR available to anyone that needs one
Darwin
Has thanked: 116 times
Been thanked: 74 times
Hey guys, ditched my old set-up in favor of a Radium Engineering direct mount FPR and no longer need either of these parts. Anyone have a use for them?
New one is a lot nicer, and you can index everything after install!
2012 VW Tiguan - Kinda stock
gruhsy
Has thanked: 48 times
Been thanked: 81 times
Interesting regulator
Are you going to be posting any review of the new one?
Zirconocene
Has thanked: 78 times
Been thanked: 48 times
@Darwin : I like that your keyboard is in Radium colors. I use their parts on my 928 S4 (2 dampers and a regulator), since the OEM replacements are horribly expensive and they've been great. I had to get creative to plumb them in but it's been a solid solution for me.
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
Fejjj951
Has thanked: 71 times
Been thanked: 30 times
Darwin wrote: Wed Apr 02, 2025 11:45 pm Hey guys, ditched my old set-up in favor of a Radium Engineering direct mount FPR and no longer need either of these parts. Anyone have a use for them?
I also have the LR AFPR and am looking to upgrade. Can you please provide the part number?
Gaspowered
Has thanked: 297 times
Been thanked: 84 times
@Darwin , just curious as to what fuel rail you're using? (stock, LR, something different?)
Brian
'88 944 Turbo S / Silber Rosa
Darwin
gruhsy wrote: Thu Apr 03, 2025 7:12 am Interesting regulator
Sure can! I haven’t torqued all the fittings yet but hope to be able to this weekend. Main reason for the change was to get rid of a 90deg AN fitting that I had the FPR+adapter mounted to. It was never meant to be a permanent set-up that way but as I wasn’t comfortable with the possibility of fatigue cracks.
Darwin
Zirconocene wrote: Thu Apr 03, 2025 10:34 am @Darwin : I like that your keyboard is in Radium colors. I use their parts on my 928 S4 (2 dampers and a regulator), since the OEM replacements are horribly expensive and they've been great. I had to get creative to plumb them in but it's been a solid solution for me.
This is great to hear! Lookin forward to a little more piece of mind with how it’s mounted!
Darwin
Fejjj951 wrote: Thu Apr 03, 2025 12:14 pm
There are no part markings on the regulator body. I’ll try and dig through my records and see if I have the receipt from when I bought it. Got it in 2011 when I did the engine swap.
Darwin
Gaspowered wrote: Thu Apr 03, 2025 1:14 pm @Darwin , just curious as to what fuel rail you're using? (stock, LR, something different?)
The rail was made by @chris white
I’ll be changing the return line fitting to a 90 so I can get rid of the elbow and the gauge will only be on to set pressure.
Gaspowered
Darwin wrote: Thu Apr 03, 2025 1:26 pm
Thanks for the pic.
Looks like you have a Silver Rose as well. With a Chris White motor, I bet it hauls.
I asked about the fuel rail because I went through 3 stock rails, all leaked, so I gave up and put on a Lindsey rail. I'm really trying to maintain a stock appearance, but I'd rather have an LR than have the car burn to the ground.
@Fejjj951 , I believe this may be the regulator Darwin is using.
I apologize if this isn't correct.
https://www.radiumauto.com/DMR-RA-Direc ... P2752.aspx
Brian
