I've read tons of topics on how to vent the coolant system on a 944 turbo, but I managed to still be confused.
Is the venting done when the coolant is hot or not? There seems to be a rule never work on a hot system to vent it, but at the same time i'm reading things like "open the vent screw and let steam escape".
I'm using a pressure vent method with 10 psi of pressure applied.
Confused about coolant venting
- Belgian951
- Has thanked: 74 times
- Been thanked: 33 times
- Has thanked: 947 times
- Been thanked: 4040 times
The low-tech way is to let the motor warm up completely, then crack the vent while the motor is still running to let out steam; then close the vent and drive around the block and do it again; then rinse and repeat until no air is left. If you have a pressure tester, you can vent the motor while cold. Apply 10-15psi at the reservoir and then crack the vent screw until it has a solid flow and isn't spitting air/coolant. You may need to do that a few times too, after driving it, as air can get trapped sometimes. A wet/dry shop vac can help keep the motor clean while venting. Assuming no head gasket leaks, the last few bubbles of air should work their way out while driving over time. If you can hear a lot of gurgling when you turn the heater on; or if the engine temp rises at stop lights and then drops quickly when you get going again; those are sure signs that you need to vent more.
- Belgian951
Thanks once again Tom!
