SOLD - 944 Late Offset Left-Side Aluminum Control Arm
Post things for sale here!
usury
Has thanked: 100 times
Been thanked: 93 times
For Sale, $30 or make me an offer.
Porsche 944, late offset, left side aluminum control arm
This is/was a previously-rebuilt control arm. I bought it in 2012 from Vertex Auto if memory and records serve me.
It is NOT rebuildable with a normal DIY kit (like the excellent Rennbay kit).
Rather, the collar and bore for the ball have been machined out and a steel sleeve pressed and pinned in place. It looks like genuinely nice work. However, there was no way to replace the ball w/o destructive disassembly. The assembly was retained from below with a formed collar and large retaining plate. I documented the Disassembly Here
So, I have this control arm that I don't need and that's probably tough to sell. You'd need a proper mill to re-do the sleeve and re-insert a ball joint. But if that's your kind of thing, this might be just for you.
and Wrench Warrior
Seattle, Washington, USA
usury
I've had this floating around my spare parts for about a year. It will require the attention of a machinist or determined DIY-er.
$30 +shipping
and Wrench Warrior
