Accessories
audi4t
Has thanked: 385 times
Been thanked: 298 times
I treated my Shark blue 992 to a couple of accessories
Hazard warning triangle in the frunk and blue gas cap cover
Has thanked: 942 times
Been thanked: 4028 times
Cool -- what's the deal on that gas cap cover? Does it go over the original or replace it? I assume the little check engine sensor remains intact. Do they come in red? :)
audi4t
This is just a cover over the original gas cap
They have red and blue below is a link to Amazon
Jaronx Compatible with BMW Fuel Cap Cover, Aluminum Metal Gas Tank Fuel Filler Cap Cover-NOT Full Assembly ( Compatible with BMW 1 2 3 4 5 6 7 X1 X3 X4 X5 X6 Z series) (Sports Red) https://a.co/d/7PMICPh
The fit is perfect - just need to pare off the little ridges on the OEM gas cap with a utility knife -
The plastic is soft.
When you test fit the cover you will see the ridges either side of the top of the gas cap handle that need to be removed that allow the cover to drop all the way down.
elm310
Has thanked: 271 times
Been thanked: 92 times
I got the Euro Triangle; I would like to get the First Aid kit.
Eric
2022 911 Carrera 4 GTS
2009 BMW e92 M3
2014 BMW f10 535i
2017 Nissan Frontier SV
2019 Yamaha AR210 Jetboat
