Upgraded my FPR so now I have a BBM adapter and AFPR available to anyone that needs one
Darwin
Has thanked: 116 times
Been thanked: 74 times
If @Fejjj951 Was asking about the new FPR then I misread and apologize.
Gaspowered is correct. If you plan to direct mount the reg you'll need to make sure the rail has a -8 ORB port.
Radium PN is 20-1623-00
2012 VW Tiguan - Kinda stock
Fejjj951
Has thanked: 71 times
Been thanked: 30 times
@Darwin
Maybe you already mentioned this but what was the issue with the FPR you were using? I have been using the LR one without issue but now that CW is doing my 3L turbo build, I am debating switching to something like the 1 you are using.
Darwin
Fejjj951 wrote: Thu Apr 03, 2025 7:57 pm @Darwin
My old setup had the FPR+adapter supported only by a 90deg elbow. Originally it was an aluminum piece but I switched to steel. Ultimately I just wasn’t happy with the fit and potential for fatigue failure so I started searching for a different solution.
Old:
Darwin
Gaspowered wrote: Thu Apr 03, 2025 3:37 pm
Darwin wrote: Thu Apr 03, 2025 1:26 pm
The rail was made by @chris white
I’ll be changing the return line fitting to a 90 so I can get rid of the elbow and the gauge will only be on to set pressure.
Thanks for the pic.
Looks like you have a Silver Rose as well. With a Chris White motor, I bet it hauls.
I asked about the fuel rail because I went through 3 stock rails, all leaked, so I gave up and put on a Lindsey rail. I'm really trying to maintain a stock appearance, but I'd rather have an LR than have the car burn to the ground.
@Fejjj951 , I believe this may be the regulator Darwin is using.
I apologize if this isn't correct.
https://www.radiumauto.com/DMR-RA-Direc ... P2752.aspx
Chris did a great job building the engine in my car. Its a 3.1L and I recently swapped to a Link ECU so the tune isn't fully done yet. Originally I had started with an electromotive set-up with manual boost controller but now I'm dipping my toes into the EBC world and trying to understand closed loop boost control.
I wish I could have my car remain stock looking. Now that I live in Cali it is impossible to switch the registration over. Good thing its still registered in TX...
chris white
Been thanked: 175 times
Gaspowered wrote: Thu Apr 03, 2025 1:14 pm @Darwin , just curious as to what fuel rail you're using? (stock, LR, something different?)
given your certification and current employment I though the whole engine would be safety wired by now!!!!
I’m still trying to get Darwin to slap a 944 sticker on one of the rockets….
Has thanked: 947 times
Been thanked: 4040 times
chris white wrote: Tue Apr 08, 2025 7:57 am
Ooooo..... Carpokes in space!! Just tell me where to send the stickers!!
:angel: :clap: :mrgreen: :shock: :shh: :thumbup: :wave:
gruhsy
Has thanked: 48 times
Been thanked: 81 times
You want one on a Phalanx? I can arrange that as there are a dozen right in front of me.
Darwin
@Tom Do not tempt me @chris white ! We literally launch weekly! I may be able to sneak one on board a second stage since it burns up lol
Darwin
Also @chris white safe-T-cable FTW
#19
chris white
Darwin wrote: Thu Apr 10, 2025 9:12 am Also @chris white safe-T-cable FTW
#20
