More power…more heat
Has thanked: 933 times
Been thanked: 4002 times
The modification I make to the shield creates a little air gap between the 3" down pipe and the shield. Without it, if the shield touches the exhaust, it becomes more of a heat conductor than heat shield... I'm sure Chris is running dilithium fuel and upsidasium exhaust parts, but for traditional 951 motors, you "shouldn't" need to wrap anything...
#21
chris white
Been thanked: 175 times
Tom wrote: Mon May 02, 2022 6:06 pm The modification I make to the shield creates a little air gap between the 3" down pipe and the shield. Without it, if the shield touches the exhaust, it becomes more of a heat conductor than heat shield... I'm sure Chris is running dilithium fuel and upsidasium exhaust parts, but for traditional 951 motors, you "shouldn't" need to wrap anything...
yeah, track motors that see full throttle 80% of the session for 45 minutes need a little extra help!
Air gap is absolutely mandatory
#22
chris white wrote: Mon May 02, 2022 6:12 pm
You should try my new E85 squirters -- it sprays a cooling stream of ethanol everywhere to keep things cool. :shifty:
#23
chris white
Tom wrote: Mon May 02, 2022 6:56 pm
Not allowed to have alcohol on the track until happy hour...
#24
chris white
BTW - trivia for the day: they make E85 with 15% gasoline in it (85% ethanol / 15% gasoline) just so it will be poisonous. E100 would be straight grain alcohol and you can make a hell of a potent punch with that (200 proof)
#25
DGUN951
Has thanked: 11 times
Been thanked: 19 times
Yep, Some of the voodoo turbo guys are running into that issue as well. Mostly on long full throttle pulls that factory shielding isnt enough . Here are some solutions
chris white
perhaps if they made little AOS dolls and stuck pins in them....:)
In my experience none of the sticky heat shieling stays in place. the glue wont take the heat.
#27
grantm951
Has thanked: 26 times
What is the secret to getting the AOS out and back in quickly with the engine in the car? Remove the intake manifold, then what else? Thanks!!
#28
johnb
Has thanked: 110 times
Been thanked: 78 times
grantm951 wrote: Wed May 25, 2022 6:21 pm What is the secret to getting the AOS out and back in quickly with the engine in the car? Remove the intake manifold, then what else? Thanks!!
I'm pretty sure the turbo has to come out first. There's a heat shield that blocks one of the AOS bolts and I don't think it can come out any other way.
#29
blade7
Has thanked: 25 times
Been thanked: 22 times
A while ago I bought a new old stock turbo discharge pipe, still with the Porsche part number sticker on it. I guess it was a very early part, as it's single skinned and therefore has larger ID . Porsche probably went to a double skinned discharge pipe to protect the plastic AOS?
#30
