A/C cuts out
BennSport
Has thanked: 7 times
Been thanked: 30 times
So I inspected the check valves and everything seems to be good. I decided to tape up the severed vacuum line that goes to the valve in the footwell I was talking about earlier and the issue is fixed! Looking back it’s pretty obvious that the line was causing the issue, but now I know. Are there any better replacements than the hard oem line? I was thinking about silicone hose like the one I have from LR in the engine bay, but the valve gets connected via the outside diameter of the hard line and that wouldn’t work.
‘83 Platinum N/A 944
#21
Been thanked: 4080 times
Have a picture of the line in question??
#22
BennSport
I sure do! That valve is now zip tied closed so I’m not getting any air coming through the heater
#23
944er
Has thanked: 14 times
Been thanked: 59 times
Poorsche44 wrote: Sun Aug 10, 2025 7:35 am I was thinking about silicone hose like the one I have from LR in the engine bay, but the valve gets connected via the outside diameter of the hard line and that wouldn’t work.
You could always use a short (like 1") section of the hard line to adapt the silicone to the valve.
#24
It looks like the plastic barb broke off and is still stuck in the hose, no?
#25
BennSport
Yes, it’s still stuck in the hose. Alongside replacing the vacuum unit I was wondering if there were any more durable replacements for the hard and brittle plastic lines?
#26
BennSport
944er wrote: Mon Aug 11, 2025 8:20 am
That’s not a bad idea, I might end up doing that
#27
