Transmission Linkage Slop
Cruise98
Has thanked: 16 times
Been thanked: 23 times
I have been happy with the Only944 linkage. If the transmission is still in the car, you will need the stubby 11mm wrench to tighten up the nut on the lever arm with the slot. At least I did.
zoom944t
Has thanked: 2 times
I am doing a new clutch, so dropped the tranny. Made the only944 linkage install a 20 minute procedure. Anxious to get it out on the track and give it a run.
stitch2k1
Been thanked: 30 times
Tom wrote: Tue Jul 12, 2022 6:00 pm I have an annoying vibration rattle that comes up through the gear shifter at certain rpms.
What RPMs?
I've been chasing a vibration problem on my S2 and a friend's 89 2.7 car that used to be mine.
Porsche 944S2 5MT '91
BMW E39 540iT 6MT '00
IG: @stitch2k1
Renn937
Been thanked: 4 times
Tom wrote: Tue Jul 12, 2022 6:00 pm I have an annoying vibration rattle that comes up through the gear shifter at certain rpms. Best I can tell, it's coming from the shifter rod (the one that runs back to the transmission). I've disassembled the shifter and have a nice new nylon bushing at the base, and greased up the peg where the rod attaches to the 5-year old shifter, but the noise is still there. I'm inclined to replace the linkage on top of the tranny, as I can get a metal on metal noise by moving it around. It shouldn't be this loose, right?
Tom, any chance you have the nylon bushing part number noted somewhere? I cannot find it listed in any of the 5 PET pdf's I have.
Has thanked: 947 times
Been thanked: 4043 times
Renn937
Tom wrote: Tue Apr 29, 2025 5:11 pm You mean this one?
https://www.autohausaz.com/pn/10353626- ... 2cEALw_wcB
Looks like I may have misinterpreted your post. I thought you were referring to the linkage on top of the transmission.
Stuttgart Motors used to have an Al option but they are long out of business it seems.
Of course only944 has a solution, albeit a short shift. I am only trying to tighten up the slop while maintaining the original characteristics.
PSU_Crash
Has thanked: 192 times
Been thanked: 114 times
I talked with Kyle over at only944 about the same issue just yesterday and decided to just replace it all. You don't have to use his short shift linkage if you don't want to. The OEM stuff is available ... and expensive
Renn937
Yeah, the best I could find was $215.
What I want is sandwiched between both #21s. All you can buy is the #18 assembly.
Screenshot 2025-05-01 114925.png (38.52 KiB) Viewed 597 times
#18
Dave W.
Has thanked: 4 times
Been thanked: 22 times
Renn937 wrote: Thu May 01, 2025 11:53 am Yeah, the best I could find was $215.
Yes you can get that piece.
I bought a new nylon shift block like the one in the video above and it completely eliminated all freeplay in the shift linkage. In fact, the new shift block fits a little tight, I had to push and twist to install it on the pivot shafts. It loosened up after a few miles of stop-and-go driving.
FYI I got it from from PartWorks. de Just search for artikelnummer 1266. The kit also includes a little packet of grease, new hardware and extra shims to eliminate any freeplay.
https://partworks.de/partworks/7261/lag ... -umlenkung
#19
Renn937 wrote: Wed Apr 30, 2025 11:06 pm
No, you were right -- that's what I was talking about, I just misunderstood what you were looking for. I'm embarrassed to admit I STILL haven't installed those parts. Been chasing other noises lately, so as soon as this one becomes the most annoying, I'll put the new bushings in. :)
#20
