I took apart my speedometer to replace a failed gear and have put it back together except installing the needle. My speedo look a little different than the picture in the gear replacement instructions as I don’t have a little metal piece sticking up (see hand drawn arrows in pictures). Also here is a picture of my needle. I align the needle pin with the hole but it doesn’t stay in. Any ideas on what is going on.
Thanks
Installing speedometer Needle
- Has thanked: 952 times
- Been thanked: 4080 times
I hate to be the bearer of bad news, but I suspect you broke the little axle shaft on the speedometer. When you remove the orange needle, it needs to pop off the metal piece shown in your first picture. Instead, it looks like the shaft broke on yours. That's why the guide looks different. Kind of a long shot, but try pushing the shaft back in and see if it seats securely. If not (as I'd expect), the path of least resistance is probably a new-used speedometer. Look at the end of the little shaft -- does it look snapped off? Can you see the other side of the broken shaft in the little port in the center of the speedometer?
This happened on my tach. Repair estimate was something like $400 from either the Palo Alto place or the LA place (I forgot the names).
I did find a reasonable used one on eBay at UK Luxury Spares - it shows up on eBay uk not eBay us, but they do ship to the us. Beware they don’t respond to questions right away and might not send you a tracking number, but I did order and receive a working part.
Mike
Mike
1986 951 - Silicon Valley
Can't hurt to try, but I wouldn't get your hopes up too high.zooklm1 wrote: Mon Mar 18, 2024 6:20 pm I tried pushing the needle in and it does not stay in. I was thinking of trying to bond it on and see if that would work. I will start looking for a replacement.
Thanks
- icb
- Has thanked: 59 times
- Been thanked: 54 times
Try Plyhammer's parts, I bet Mark has a ton of speedos in the shop right now. As Tom suggested, the odometers are pretty easy to set to any mileage you want if you are so inclined. If you just repaired yours, it's easy to swap the odo into a replacement.
Excited to say I came up with a DIY fix for broken Speedometer needle shafts. Will post details in a separate thread in the morning.
