Well, I’m in luck…the pen the dealership gave me appears to be correct!
If it wasn’t for this thread, I too, would’ve never noticed the glove box clips. Thanks @Larry C !
What did you do to make your 718 unique?
- JodehFoster
- Has thanked: 57 times
- Been thanked: 89 times
2018 718C S 6MT
2021 Macan GTS
2021 Macan GTS
- P_Coastal
- Has thanked: 1044 times
- Been thanked: 616 times
Agreed, looks goodLarry C wrote: Mon Mar 06, 2023 11:08 am @allen718 what did you use for the small PORSCHE letters on the SD slots cover? Looks OEM
I used water based acrylic craft paint. I first practiced on the PORSCHE lettering on the owners manual cover before painting the letters below the nav screen. Use a small brush to fill in the recessed letters, let it dry for maybe 10 seconds, then gently wipe off with a moist paper towel and the flat part of your finger. Keep wiping with fresh paper towel section until all the surface paint is gone. It may take a couple of cycles to get it all filled in. Also, I taped off the areas around the letters and laid a clean drop cloth on the interior to prevent any spills- just in case. Pretty easy and fun little project. And you notice it every time you get in the cockpit. I don't know why the factory leaves it unpainted.
- Has thanked: 4446 times
- Been thanked: 2414 times
Very cool!allen718 wrote: Mon Mar 06, 2023 2:11 pm I used water based acrylic craft paint. I first practiced on the PORSCHE lettering on the owners manual cover before painting the letters below the nav screen. Use a small brush to fill in the recessed letters, let it dry for maybe 10 seconds, then gently wipe off with a moist paper towel and the flat part of your finger. Keep wiping with fresh paper towel section until all the surface paint is gone. It may take a couple of cycles to get it all filled in. Also, I taped off the areas around the letters and laid a clean drop cloth on the interior to prevent any spills- just in case. Pretty easy and fun little project. And you notice it every time you get in the cockpit. I don't know why the factory leaves it unpainted.
By the way, welcome to Carpokes! Glad to have you here. There are a lot of great people posting all kinds of good things so we welcome your input - join in all you want!
We have a New Member intro thread in the event you want to introduce yourself. We like pics - lots of 'em, so post away if so inclined.
New Member Welcome sub-forum > intro thread: https://www.carpokes.com/viewtopic.php?t=48
- Larry C
- Has thanked: 592 times
- Been thanked: 667 times
Very cool. Another touch of understated bling. I like that you can select a color to match your interior stitching, seatbelts, etc.. Thanks for posting.allen718 wrote: Mon Mar 06, 2023 2:11 pm I used water based acrylic craft paint. I first practiced on the PORSCHE lettering on the owners manual cover before painting the letters below the nav screen. Use a small brush to fill in the recessed letters, let it dry for maybe 10 seconds, then gently wipe off with a moist paper towel and the flat part of your finger. Keep wiping with fresh paper towel section until all the surface paint is gone. It may take a couple of cycles to get it all filled in. Also, I taped off the areas around the letters and laid a clean drop cloth on the interior to prevent any spills- just in case. Pretty easy and fun little project. And you notice it every time you get in the cockpit. I don't know why the factory leaves it unpainted.
- P_Coastal
I am fascinated by the impact that makes, I wonder does the door pop off easy enough to make the painting easier and less risky ?
I'm not aware the door can be removed. Based on the way it operates, I would guess not. I considered removing the head unit so the surface would be facing up but after practicing with the owners manual cover in the same position as the cockpit lettering, it worked just fine as is.
Thanks for all the complements on this. I'm glad it was successful. I wish I could say the same for trying to paint the PORSCHE lettering on the plastic battery cover in the front. That was a complete failure after several attempts and had to respray it to get the finish back. This is the kind of stuff I monkey with during the winter.
Added an additional red item to the interior today as I purchased a red Dial Mode Cover to my interior. Looks very cool and another pop of red always helps. Thx Tom...![Image]()
- IMG_1212.jpeg (2.86 MiB) Viewed 1466 times
