Must have accessories
Wow, I wonder why they decided not to make them anymore? I picked up a set for my 2022 CGTS about 2 months ago, when they had them in stock. Also got the Radiator Grill Store (RGS) grills for the side intakes, since I don't like the way the Zunsport side intake grills sit outside the side intake strake instead of behind it like the RGS version. Now I just need my car to be delivered! It's waiting at port for the model year 2022 EPA/CARB certification.
- Larry C
- Has thanked: 592 times
- Been thanked: 668 times
I just received a fourth email from Zunsport. I’m now being told that they are out of stock but will still carry the GTS front grills. I’ve been very clear with my inquiries but I’m not sure English is their first language. Anyways I’m pleased that they will be stocking the product!
- Larry C
Are you happy with the fit on the front outside grills? Some have reported that they don’t fit well. How long did the install take?
- Larry C
Has anyone purchased a cargo net (OEM or aftermarket) for their Cayman or Boxter? I’ve heard that the OEM doesn’t fit well - too loose.
Get the Zunsport grilles! I was following a logging truck (yes, I kept distance) and it lost a small piece of wood which lodged itself in the grill. It would have made a mess of one of the radiators! Paid for itself then and there. By the way, no damage to the grille.
- Throttlesteer
- Has thanked: 15 times
- Been thanked: 38 times
I used the CCG ones. They also work well and installation wasn't too bad. You do have to contort your hands in a few different ways to get it lined up correctly. Zip ties make it nice and clean without having to drill.
- Dougzander
- Has thanked: 10 times
- Been thanked: 5 times
I ordered the Zunsport grills through Amazon. Easy install, look a great and function as expected.
- Bill in Bama
- Has thanked: 16 times
- Been thanked: 155 times
Here's a list of some of mine, I probably won't remember them all....
Zunsport grills front and side, easy install.
Blendmount w/ V-1 gen 2 and SAVVY mount in OBDII port, easiest way to get power.
Changing CF wheel for custom all leather w/ contrasting stitching (work in progress, you can follow my journey on another
thread if you are a masochist.
Cupholder to replace the ashtray
PPF on front and around wheel arches.
Ceramic coating
Clear side markers
Carpoke rear license plate mounts
Porsche crest valve caps
CF and body color key accents-CF from eBay and I painted the other myself.
Compared to my previous 981 GTS this is skimpy so far.
2021 718 GTS Aventurine Green Metallic w/ Expresso/Cognac leather. Satan Platinum wheels.
Ceramic coating
Clear side markers
'84 944, my first Porsche DBM
