Looking for - Rear Hatch Lock Ring
eccs19
Has thanked: 45 times
Been thanked: 5 times
Not sure the actual name (Sealing Ring maybe), but the ring that surrounds the hatch lock cylinder. Anyone by chance have a STEP or STL file for this? (1983 944) I believe the part number is 477-827-529A
robstah
Here ya go:
hatch_lock_grommet.3mf
I normally print it in TPU (TPU for AMS, which is harder, but any TPU will work), face upward with supports. It can be a tight fit so I lube it a little bit, get it to go in most of the way, and then use a socket that will clear the lock cylinder and lightly tap it in until the outer lip tucks in and is flush. Might not need to do that with softer TPUs.
