Kroon Harness for 944 Turbo
Mscromer
Has thanked: 43 times
Been thanked: 22 times
turbotoys wrote: Wed Jul 22, 2026 9:19 pm
NCGermerican wrote: Wed Jul 22, 2026 12:48 pm
turbotoys wrote: Sun Jul 19, 2026 8:28 pm
Dennis... I just looked at my startup logs today. Note it's HOT out and my starting ICT temps were 99F. The ICV was closed down to 10% ish and got to 40% within a minute. Now.. My issue is that the cold idle is in the 750 range and when warm heads towards 850.
Tomorrow, I'm going to get it up to 195F and properly set the ICV and idle and see if the grounding of the orange/black makes a difference. I'll let you know
Thank you sir! Looking forward to seeing the results after shorting out the MAP pigtail. I've done the same and hope to see what happens tonight. One thing to clarify - when you say the ICV was closed down to 10%, does that mean the ODB+ showed 10% open or 90% open (meaning 10% closed).
Man do I hope Joe chimes in on this to put it to bed. It's making my head spin.
.......maybe I should have just spent another $1K on the Kroon Harness and gone the MAXXECU route.........
An update... While my idle was "good" where it's improved is when the car is 100% cold. I can now drive it right away and it's smooth. In general it's a bit better and I'm happy with how it's running.
I’m glad this F9 DME quirk is getting out to everyone. It was a big improvement on how my car idled. I just don’t understand why F9 doesn’t tell everyone to short out the MAP plug when you purchase one. It would save a lot of people headaches chasing down rough or poor idles. I was chasing mine down for 2 months.
#191
Latitude48
Has thanked: 107 times
Been thanked: 116 times
Duplicate Deleted
Tom Pultz
#192
Latitude48
Mscromer wrote: Thu Jul 23, 2026 5:02 am I’m glad this F9 DME quirk is getting out to everyone. It was a big improvement on how my car idled. I just don’t understand why F9 doesn’t tell everyone to short out the MAP plug when you purchase one. It would save a lot of people headaches chasing down rough or poor idles. I was chasing mine down for 2 months.
I posted a note on RL and Joe responded:
"Yes, this is correct, I have been shipping OBD+ Sport DMEs with a special plug for the MAP socket. Apparently, the analog signal ADV28, which is normally exposed on the 35pin System Connector, puts the DME program into a special mode related to the ICV when not grounded. The special plug I now provide just shorts ADV28 to ground just like the factory does at the DME harness. If you, or anyone else, would like this special plug rather than using the provided pigtail harness, please email me directly at [email protected]. In this case, please provide your current shipping address and I will send you one at no charge. Another option is for me to solder in a high-value pull down resistor. However, I have not yet established an appropriate value for this resistor, and you would need to send in your OBD+ Sport DME to have this done. For now, the workaround is to simply install the provided 4pin pigtail harness into the MAP connector then connect the orange and black wires together."
Tom Pultz
#193
Been thanked: 4088 times
Latitude48 wrote: Thu Jul 23, 2026 3:51 pm
Thanks for posting that here. If you get a chance, see if you can encourage Joe to post updates here on Carpokes too. I hope he doesn’t think we’re being critical when we flag these things. We’re raising them only to help make a great product even better. And let’s face it—most of the good propellerheads are over here on Carpokes these days. :)
#194
Latitude48
Tom wrote: Thu Jul 23, 2026 5:11 pm ...
I have a propellor on my head, ha, ha? I'm a retired Boeing Propulsion Engineer... but years ago when I was a younger guy I worked with my father, who owned Aircraft Propellor Service, Inc at Sky Harbor Airport in Northbrook, Illinois. I loved working on the old wooden props. Wish I kept one.
Tom Pultz
#195
Mscromer
Latitude48 wrote: Thu Jul 23, 2026 6:41 pm
So we have a lot of aviation people here on carpokes? I’m currently a F-35 mechanic at Lockheed Martin.
#196
Mscromer wrote: Thu Jul 23, 2026 7:37 pm
I have 16 logged hours in a Katana DA20 -- very similar to an F-35. :lol:
#197
Tom wrote: Sun Jul 19, 2026 5:36 pm I posted this in a separate thread but see this video for pretty compelling evidence the F9 data log is directionally backwards…. The ISV itself seems to work as intended, but the % Open reported in the logging software just seems wrong.
Joe wrote this in the comments to the youtube video, just FYI: I was able to confirm there is an issue with the ICV Parameter. I will work on it next week; I expect to have it resolved within a week or two.
#198
NCGermerican
Has thanked: 144 times
Been thanked: 98 times
Tom wrote: Sat Jul 25, 2026 5:45 pm
That is AMAZING news! Based on your video, I do think it's reversed - 90% open really means 90% closed.
So - if I'm showing 93% CLOSED at idle, could that mean:
1) I really do have a vacuum leak - however I do think I would have a high idle the ICV couldn't compensate for, if that's the case.
2) Maybe I didn't set the idle stop screw correctly and the throttle is letting too much air through - even though the TPS clicks as it should.
3) My idle adjustment screw was 2.5 - 3 turns out from the bottom. From what I read, it's usually closer to .5 - 1 turn from fully closed.
#199
NCGermerican wrote: Sun Jul 26, 2026 10:46 am
The video definitely suggest the reported number moves in the wrong direction. It certainly could be as simple as it being mislabeled % OPEN instead of % CLOSED, but if it were that simple, you'd think Joe would have just said that? "Work on it" and "expect to have it resolved in a week or two" sounds like more than that to me -- though I could be reading too much into his choice of words. At any rate, nothing in my experience or Joe's comment makes me think this is an actual control issue, but rather just an errant logging value. In other words, I doubt it's the cause of any of your issues -- other than perhaps throwing you off the scent with incorrect telemetry.
#200
