This is where mine sits after rotating
IMI vs WOSP starters - clearance issue?
I installed an IMI starter today, and it’s a fraction shy of 5/8” from the oil pan fins to the starter (with the oil pan being lower). Installed as received. I did have to tap the aluminum shield a bit on the left side, and the stock M12x50 bolt (goes through the bell housing on the left) wouldn’t tighten due to hitting the new starter, however, an M12x45 worked just fine.
1988 944 S
Gone, but not forgotten
1993 964
1981 911SC
1993 964
1981 911SC
