WTB: Aluminum Under Tray
Spencan
Has thanked: 130 times
Been thanked: 31 times
my car is missing it and I would like to have it. I already checked with Lart and 944 Barn but no luck. Anyone have one lying around?
gruhsy
Has thanked: 48 times
Been thanked: 81 times
New from Porsche Classic parts
95150406900
johnb
Has thanked: 110 times
Been thanked: 78 times
Check the studs on the frame rails. I haven't been able to reinstall mine because the threads on the studs are shot. I don't think the rails are thick enough to tap for a new stud, so I think it has to be welded on if you need a new one.
Spencan
Thanks for the part# too. I found one on Ebay.
Has thanked: 945 times
Been thanked: 4037 times
johnb wrote: Mon May 16, 2022 12:55 pm Check the studs on the frame rails. I haven't been able to reinstall mine because the threads on the studs are shot. I don't think the rails are thick enough to tap for a new stud, so I think it has to be welded on if you need a new one.
I used a die on mine to cut M5 threads. It went from undersized to even more undersized, but it does hold. If I ever weld a stud on there, it's doing to be at least M8....
edit: or maybe a rivnut in the wall...
Doyle623
Has thanked: 13 times
Been thanked: 7 times
I'm considering adding one of these to my car as well.. https://www.delawareporscheparts.com/cart has them for $140 plus shipping.
1986 944 Turbo - Vitesse MAF (Stealth), Evergreen K27/8 Raptor, Kroon, Ftech9, KW V3, etc.
2005 911 Carrera S Launch Edition
