Page 1 of 2
Garrett GT 3071-63 turbo.
Posted: Sun May 24, 2026 5:51 am
by blade7
Has anyone fitted this turbo, and was it an improvement over the standard 26-8?
Re: Garrett GT 3071-63 turbo.
Posted: Sun May 24, 2026 9:16 pm
by PSU_Crash
I run the GTX version with .63 A/R hotside on my non porsche 80s turbo beast. Dual ball bearing is the big gain there. Still makes 400WHP and spools up fast.
Posted: Mon May 25, 2026 3:33 am
by blade7
PSU_Crash wrote: Sun May 24, 2026 9:16 pm
Thanks for the reply. It's mainly the original standard GT3071 turbo I'm interested in. Is the main benefit the ball bearings, or is there more, that makes the extra fabrication work worthwhile.
Posted: Mon May 25, 2026 9:42 am
by PSU_Crash
With the standard GT series I think the ball bearings is the biggest improvement. I'm sure the blade tech is also more efficient than 40 year old OEM. I haven't looked at a flow map side by side. That will really give the answers you seek.
Stock turbo loses effeciency around 17ish psi. The GT is efficient up to around 30psi. If power is the goal, the GT is the answer.
Posted: Tue May 26, 2026 2:01 am
by blade7
TBH driveability is what I'm interested in, without going to a smaller turbo than the K26-8. All of my fun 944 driving is on twisty roads now, so boost starting from under 3k would be more use than at 6.5k. Having said I don't want it to feel choked at 6k.
Posted: Tue May 26, 2026 3:54 am
by PSU_Crash
Hopefully someone chimes in that has run this setup. On my 2.6 mitsubishi 4 cylinder the GTX is at 18psi by 3k RPM. That's also a fully built engine, so it may not be apples to apples.
Posted: Tue May 26, 2026 4:33 pm
by blade7
Surprisingly considering how long these GT turbos have been around, there's not much 944 turbo info available.
Posted: Wed May 27, 2026 4:00 am
by PSU_Crash
Posted: Wed May 27, 2026 4:45 am
by blade7
Thanks, as far as I know he still hasn't finished building that car 15 years later. It was in a 911 workshop around 10 miles from me until recently.
Posted: Wed May 27, 2026 7:41 am
The 951 crowd has always leaned into vendors selling turbos as Stage this, Voodoo that, Raptor, SuperX, etc. Somebody posts good results with one, and others jump onboard. It makes getting feedback on off-the-shelf turbos like this harder than you'd think it should be... That's not to say there aren't plenty of pioneers out there, but we could use more.
