DIY Painted Scoops and Ducktail Spoiler
webkris
Has thanked: 18 times
Been thanked: 28 times
Most car guys I meet are afraid of body work, or down right loathe it. The learning curve is steep and starts with taking various compounds of sand paper to your car and ends with a fog of paint smells rolling out of your garage while wearing a respirator for hours. If you do have some experience with it, you know that the process takes days. Time to let the primer dry, time to mix the filler, time to let the filler dry, time to sand the filler, time to add more, time to prime, paint, clear, etc, etc. It's a skill that starts with patience. Can't be in a hurry.
I learned that you don't need a paint booth, or an expensive spray gun, to tackle modern paint work. I finally got the courage to try some techniques when watching the "Greasy Fingers" channel on YouTube - specifically this video. Paint can be applied with a rattle can, or a hobby air brush. You don't want to paint a whole car this way, but stop worrying about the tool that applied the paint, and focus on the final product. The key for me was learning about 2 part epoxy clear:
"USC SprayMax 2K Glamour High Gloss Aerosol Clear" on Amazon
This unlocks an automotive level paint finish in your garage that is exactly like the clear coat already on your car.
At he bottom of this magic can is what looks like another nozzle. The red button stored in the cap goes here and activates the paint with hardener that's stored inside. Once activated you have about 48 hours to use up the can. At $40 a can, you better be ready to use it on everything you need to clear coat. I have the nicest mailbox on the street. ;)
We start with "Bondo" body filler. I scuffed up the stock surface to ensure the filler would stick well. Mix; Fill; Sand, and repeat until any tiny holes are filled. Gaining experience applying an even coat is what means you won't have to do this 3 or 4 times, but just know that you can always sand it off and try again.
Let the filler completely harden 24 hours+ before wet sanding. Now the dusty part is behind us and we'll wet sand the rest of our work. I picked up a pack of 2" wet sanding squares, and I started with a 300 grit to knock this down quickly, and moved to a 500 grit to get the surface flat. You'll see in these pictures I'm using the reflection of my garage lights to determine the surface flatness. Having a utility sink is nice, but you can layout some towels on a workbench.
I then moved on to a sandable primer, and repeated sanding smooth with a 500 and then 800 grit. Primed again and let completely harden for 24 hours and worked the scoops and wing with 1000 grit until the surface was perfect. This is why paint and body work is so expensive. Between every coat I wipe down with IPA and a fresh microfiber towel to remove any dust before applying paint.
I've had great success with paintmatch cans from "ScratchesHappen" on Amazon. The paint match is perfect and obviously your results may vary here. They include a card to test, and if it's off they will work with you to nail it. Night Blue Metallic looks matte and almost black when done, but in the sun all your little mistakes will be revealed. :shock:
The duck tail spoiler required another round of paint and wet sanding, and took a lot more paint initially than expected. This is an aftermarket fiberglass one, and soaked up paint like a pine board. At $50 a can for custom mixed paint, consider that you would need to have access to a paint shop with a computer mixer, so IMO it's a pretty good deal. I would have used less if I was a little more careful getting blemishes out with cheaper primer. I am wet sanding after every coat of paint. With dry time this is DAYS of work - at a couple hours a day. You're not in a hurry right? Sandable primer dries pretty fast, but the more you allow it to harden the easier it is to sand by not filling your sandpaper with sticky paint.
Clear coat time! I ordered a second can of 2 part clear after I ran out of mixed paint on the wing. I knew I'd need it.
I start with a light coat to get the paint to stick and then roll on a heavy coat in a steady smooth motion to get that gloss finish. Wait 2 minutes and then repeat. There are going to be small imperfections and specs. Don't worry, you can wet sand this too. For the clear I start with a 1500 to knock down the spots, and 2000 to get it smooth.
Cut and polish. Cut and polish. Repeat again. I needed more effort on the wing as the orange peel was a bit more obvious. I'm glad I did two separate heavy coats of clear on it. This allowed me to sand on the car without fear that I'd wear through the remaining clear, and work on it with a 6" random orbital polisher after with a cut compound followed with a polish.
I'm proud of the results. I had tried some "aftermarket" scoops last year, but they were a disaster. The OEM scoops come with primer on them, so they took way less time even with the bondo filler. I wanted them for grabbing more air at the track and to give me an OEM+ look. I hope this encourages some of you who were on the fence about trying more paint work.
- Kris
Has thanked: 4604 times
Been thanked: 2498 times
Great job!
As you said, lots of work. Patience must be the keyword, along with the ability/willingness to learn through trial and error. Sufficient time helps too. :)
J-Dub
Has thanked: 669 times
Been thanked: 582 times
Great work!
I am the guy you described in the first part of the post. I will change your clutch, you paint my fender! Please and thank you!
Bought GT4 scoops with the logo filled an painted. Had my front and rear spoiler painted by the local body shop.
Got to know what projects you will find fun and which ones you will not.
Keep having fun!
Jeremy
1957 VW Beetle
2004 VW R32
2021 Porsche Cayman GTS 4.0
PSU_Crash
Has thanked: 234 times
Been thanked: 127 times
Looks great!
Body work does indeed have a steep learning curve. It took me 5 years to finish body and paint on another project car. I say finish, but it still needs a final sand and another coat of clear. Take your time to get results. However long you think body/paint will take, multiply by 5, at least :D That said, after this last project I could do it again in a fraction of the time. There are thousands of ways to scew it up. I found most of them along the way :crazy:
PSU_Crash wrote: Tue Aug 26, 2025 4:02 am Looks great!
:lol: :thumbup:
Great post and even better work on the paint! I used the SprayMax on a piece of my old Mercedes and it's held up strong for over 5 years now. I got some orange peel, which I probably could have sanded out, but it looks good overall -- not like a rattle can paint job. The only thing with those cans is that, once activated, you need to use the can within a day or so, as the paint will harden in the can within 24 hours or so.
jkat
Has thanked: 4 times
Been thanked: 5 times
Nice work. How involved was the install of the side scoops?
webkris
jkat wrote: Tue Aug 26, 2025 8:52 am Nice work. How involved was the install of the side scoops?
Thanks!
If you undo the 4 torx screws from the rear fender and the ~8 plastic clips under the sill plate and under the car, you can peel back the side skirts very easily. This way you can make absolutely sure that scoop is not coming out. The scoop and the black plastic clip together to form the one piece that snaps in perfectly.
I'm not sure where the factory installs screws, but this made the most sense to me. The front one locks in the black plastic and the top grabs the scoop plastic itself. Along with 4 pieces of VHB tape to secure it. You can also see I re-attached my grill protection which fit exactly like the stock "two bar" grill.
"That's not going anywhere" :D
jkat
Thank you. I've been thinking of doing the same mod to get more air into the airbox and intercooler on track.
