My new 944 ... and it's issues
Posted: Thu Apr 10, 2025 10:40 am
I just took delivery of this beautiful beast yesterday. From 20ft, it is quite lovely.
Then we look a little closer at the "new paint job" I'm not surprised, I was just hoping for better. Most of the trim/seals are sprayed to some degree, but they are mostly in rough shape anyways and will get replaced.
Now the REAL fun! It has an aftermarket security system. After some research I believe it is a Voxx. Due to this wonderful security system it took almost 2 hours to get it started when it was delivered. Time to find the brains and get this system gone! Any advice as to where I may find the controller for it?
More wiring fun! What did this used to plug into??
Expert repair ...
Mystery relay
Another one ... and the air horn pump
Going to need a boot/grommet here sooner than later
Could not get the hatch to open. Then found this in the back seat
While I'm at it, what do these 2 buttons do to the left of the fan speed?
This is just what I found within an hour of having it in the shop. Also discovered the wipers, power windows and mirrors don't work. I only got as far as checking fuses for electrical issues. The sunroof works at least!
Brakes are questionable. something is loose in the steering linkage, front left bumper shock is compressed a bit and the shifter is about as tight as a hot dog in a hallway.
I knew what I was buying (mostly) and I'm not scared of fixing anything. The German engineering learning curve begins! I may need some advice along the way from you fine enthusiasts.
Expert repair ...
Mystery relay
