Super Cold Blooded on cold start
Mshawnbauer
- Been thanked: 6 times
It doesn't matter if it's 98 degrees of 15 degrees, if she sits for over a couple hours, she's super cold blooded. She'll pop right off, then die.. She'll start right back up again and idle kind of rough for a few minutes (literally) but then I can give her the beans a few times and she's good go! Runs like a champ the entire drive, every time. BUT! Just a bit groggy at cold start. I replaced the blue temp sensor hoping that was it, but nada. What do you all recommend? Any Ideas? Thank you in advance!
- Been thanked: 4080 times
I'd start by checking the DME temp sensor, AFM temp sensor and idle contact switch, all at the 35-pin DME connector (to root out harness issues and sensor issues). If those are all ok, I'd check the O2 sensor, and then spark strength.
