Headlight Motor Helicoil Drill Jig
Posted: Thu Jul 18, 2024 10:23 am
I had to remove the 944 headlight motor the other day, and one of the bolts pulled out all the aluminum threads with it. As is my way, I created this drill guide to drill out the hole for a helicoil insert. M6 Helicoils take a 1/4" drill bit, and this jig ensures the hole you drill will be centered and straight. :)
Porsche Headlight Motor Drill Jig.stl
Re: Headlight Motor Helicoil Drill Jig
Posted: Fri Jul 19, 2024 9:26 am
by noddy1
Nice one!
Posted: Fri Jul 19, 2024 10:08 am
by icb
You should get some steel 1/4 ID tubing cut to size, harden it with a torch and some light oil, and press it in there, that would be really slick
Posted: Fri Jul 19, 2024 10:14 am
icb wrote: Fri Jul 19, 2024 10:08 am You should get some steel 1/4 ID tubing cut to size, harden it with a torch and some light oil, and press it in there, that would be really slick
In that spirit, McMaster sells precision drill bushings, which I used in the water pump stud drill jig linked below, since the stakes are so high when drilling into the block, and since the bit seriously wants to jump off the broken steel bit and over to the block's soft aluminum.
viewtopic.php?p=5085
For the headlight motor, it didn't seem worth it, but maybe that's just because there was no broken bolt in mine. :silent:
Posted: Mon Feb 02, 2026 8:23 am
by 928Kyle
Tom wrote: Thu Jul 18, 2024 10:23 am I had to remove the 944 headlight motor the other day, and one of the bolts pulled out all the aluminum threads with it. As is my way, I created this drill guide to drill out the hole for a helicoil insert. M6 Helicoils take a 1/4" drill bit, and this jig ensures the hole you drill will be centered and straight. :)
944 Headlight Washer Pump Drill Jig by Carpokes.stl
Hey Tom, looks like you have the incorrect STL posted for this thread?
Posted: Mon Feb 02, 2026 9:14 am
928Kyle wrote: Mon Feb 02, 2026 8:23 am
Yikes, I wonder how long that's been there!! Thanks for the heads up. I'll find the right file and post asap. Are you looking to use it?
Posted: Mon Feb 02, 2026 9:17 am
Updated the first post with the correct file. Thanks for the heads up!
Posted: Mon Feb 02, 2026 9:26 am
by 928Kyle
No immediate need, just adding it to my Porsche tools arsenal. Thanks for updating the file!
