Based on a thread in the transaxle section I've been playing with some modeling for a 3d printed intake manifold. I started this to share some of the technical files with a larger group.
The DXF was created from a provided PDF of a technical drawing. The STEP is the dxf extruded to 15mm and the holes opened for compression limiter inserts (these are chunks of metal that prevent a bolt from destroying plastic when torqued)
See here for the larger thread: https://www.carpokes.com/viewtopic.php?p=34828
