New 992 and interior ticking noise?
Posted: Sun Dec 05, 2021 12:37 pm
by Cst
Hey guys , hopefully someone can take a look at their cars and see if you notice the same thing.
Motor is off and cold without turning on anything...
I have a 2022 C2 with less then 200miles. When the car is completely shut off I hear an electronic ticking noise almost like a clock tickin coming from under the armrest and sometimes out of both doors near the seat memory buttons.
It goes away when turning the start knob on. (Don't have to start the motor)
its loud enough to be quite annoying. I opened the windows and locked the doors and its still ticking away a couple hours later..
been doing it since day 1
Anyone notice anything in your cars ?
Re: New 992 and interior ticking noise?
Posted: Sun Dec 05, 2021 5:06 pm
by svkarl
Mine's a 2021 with just over 3500 miles. It makes some noises from time to time, but nothing regular or consistant and mostly if it's recently been run or I've been around it with the key. If if's been off for a while and the key is not nearby, zero sounds. Either, way, no regular sounds like a clock.
Posted: Sun Jun 30, 2024 10:50 am
by happyinmaui
hi- i am a new member to Carpokes.
i saw your message.
i have the same problem. it's been present ever since I received the car.
when i asked the service department, they weren't aware of an issue. next time i take it in, I'll ask
now 1.5years later, the ticking persists.
how are you doing?
Posted: Sun Jun 30, 2024 11:00 am
by Cst
The ticking turns out to be the sensor that locates your key fob. If u turn off the peripheral sensors for the unlocking the doors....I forget the actual word for it ...it should go away......and also the key fob battery may not drain as fast. Good luck
