What is an Engine Control Fault?
rbpeirce
Been thanked: 15 times
It says take it to the shop but ok to drive. I have a track event Thursday.
In the event I can’t get it fixed by then is that ok to drive?
2016 Audi A7
2021 Porsche GT4/PDK
71eh
Has thanked: 200 times
Been thanked: 565 times
You might want to forget about the track day until you get it sorted out by your local Porsche Mechanic... No way to tell how serious the fault is until its diagnosed.
It could be anything...
Tank vent valve
PDK issue
Evaporation leak
Gas cap leak
Misfire
PSM issue
But for sure just wait till it's diagnosed... While it says its "Safe to Drive", that does not mean its "Safe to Track" :lol:
I once had a fault on my Macan GTS similar to yours... Turned out to be just grease on a sensor :wtf:
'24 Porsche 718 Cayman
'21 Mercedes AMG GTR
'76 Triumph TR6
'23 Porsche Macan GTS (sold)
'22 AMG CLS53 (sold)
'22 AMG CLA45 (sold)
'20 AMG c63s (sold)
Has thanked: 945 times
Been thanked: 4040 times
Make sure your gas cap has 'clicked' shut. If not, it will set off that light. Click it tight and see if the light goes out in a day or two. You can also pick up an OBDII code ready for peanuts these days and see what the fault is. They have them at most auto parts stores and, of course, Amazon...
Stormy_Monday
Has thanked: 353 times
Been thanked: 456 times
I've had this twice now on my '22 4 liter. First was the transmission speed sensor. Last week at my two year service the tech said it was due to the cooling fans not turning off. A known problem. They flashed a fix. So we'll see.
Red Cars Rule
2022 718 Boxster GTS 4.0
2025 Cayenne e-Hybrid
2015 Ferrari California T
rbpeirce
I don't have a code reader but my mechanic does. I'll have to see what the problem is and maybe call the dealer. The car is still on warranty.
2016 Audi A7
Pachanga718
Has thanked: 236 times
Been thanked: 127 times
71eh wrote: Sat May 18, 2024 2:21 pm You might want to forget about the track day until you get it sorted out by your local Porsche Mechanic... No way to tell how serious the fault is until its diagnosed.
Tank vent valve
PDK issue
Evaporation leak
Gas cap leak
Misfire
PSM issue
This is good to know about what it could be - almost like a Porsche specific CEL
rbpeirce
Turned out to be P2C4100: Engine compartment purge fan 1. Reset and works fine.
I suspect a piece of track rubber momentarily stopped the fan and then fell out. I had a similar problem a couple of years ago where the fan actually got jammed! I need to get side inlet grills.
2016 Audi A7
Has thanked: 4484 times
Been thanked: 2435 times
rbpeirce wrote: Fri May 24, 2024 6:04 am Turned out to be P2C4100: Engine compartment purge fan 1. Reset and works fine.
Good info! Thank you for the update. :thumbup:
