944 N/A Throttle Response Cam
Posted: Mon Mar 25, 2024 6:48 pm
Here are STL files to print a throttle response cam for the 944. It's broken into pieces so that they can all be printed flat with no support, to ensure a smooth channel for the throttle cable to ride in. ABS holds up under the hood reasonably well, whereas PLA will go soft and should not be used. Consider this an experimental/evaluation part. While it might last quite a while under the hood, you are better off buying a metal version if you like it and plan to use it for extended periods. I used ABS, .08mm layer height, no support, no brim, smooth PEI bed, random z seam alignment (scarf seams if available). Use a vice to press the pieces together and make sure the parts are pressed together completely -- it should look like once piece when assembled, with zero gaps between the separate pieces.
(Print 2 of the center pieces)
