exhaust bubbles after exhaust manifold gasket change
Belgian951
Has thanked: 74 times
Been thanked: 33 times
I just changed out the exhaust manifold on my 86 951, including all the studs, new washers and nuts (rennbay kit). I also changed in new exhaust manifold gaskets.
Now with the soapy water test, it seems that I have a few small leaks at several nuts/studs. Also, some gaskets seem to be 'cooking', with tiny bubbles on the top edge. All nuts are torqued to 15 nm.
I'd rather not fail my MOT emissions test again. What is my course of action to solve this once and for all?
Edit: the car hasn't been driven since these changes, just tested. The soapy water test was done when the engine was cold. Can't verify if the manifold continues to leak after engine is warm since the water evaporates so quickly.
Has thanked: 521 times
Been thanked: 266 times
Best of luck with the MOT.
michaelmount123
Has thanked: 26 times
Been thanked: 179 times
Tightening the exhaust manifold to the correct 20nm will probably solve your leaks. A heat cycle will help too.
Has thanked: 947 times
Been thanked: 4040 times
I'd be curious what brand exhaust gaskets you are using? I've never heard/seen those gasket 'cook' and bubble?? Have any pictures of that?
Normally I drive the car over a couple days and then go back and torque to spec. Invariably some are a bit loose after the header expands and contracts a few times...
Thom
The First Carpoke!
Has thanked: 138 times
Been thanked: 153 times
I always tighten headers nuts to how tight enough it feels to me and that is way higher than 15 N.m.
Exhaust temperature can get brutally high on these engines and there is no way that 15 N.m can be tight enough. That's the torque figure used for 16 mm motorbike spark plugs.
'90 944 turbo
Thom wrote: Fri Jan 26, 2024 1:40 pm I always tighten headers nuts to how tight enough it feels to me and that is way higher than 15 N.m.
I totally missed that, but yes the factory spec is 15 ft lbs. (or 20 Nm) -- not 15 N.m. That might explain to poor seal.
Belgian951
I used these reinz gaskets (OEM normally I believe, 944 111 196 01)
WhatsApp Image 2023-10-24 at 15.09.23.jpeg (76.64 KiB) Viewed 843 times
I'm now unsure whether I did 15 nm or 20 nm of torque... I'll recheck asap and then test again. I'll also try to get a picture or video of the bubbling.
Belgian951 wrote: Fri Jan 26, 2024 3:26 pm I used these reinz gaskets (OEM normally I believe, 944 111 196 01)
Try the re-torque for sure. Very curious about the bubbling....? Can't quite picture what's going on there. The shiny side goes toward the headers.
Belgian951
I rechequed the torque today and it was indeed torqued to 15 nm instead of 20 + 2 nm. After torqueing it to the correct value, I tested the car again with the soapy water test. No leaks! Thanks everyone.
Tom, I tried to film the bubbling, which is still present. I think it may be oil or something that is burning off slowly. You can just make it out in this vid, but barely:
