Page 1 of 2
Adaptive Cruise Control
Posted: Fri Oct 27, 2023 5:01 pm
by penhosky
While doing diagnostics on my Panamera I allowed the battery to run down and could not restart it. I used a charger overnight and was able to restart it the next morning but I had two codes go on. One was spoiler failure, which cleared on the second re start. The second one, which doesn’t clear, is “ ACC unavailable.” That’s the Adaptive Cruise Control. Never did it say “ Service needed.” Any thoughts on resetting without a visit to the dealer? Thank you.
Re: Adaptive Cruise Control
Posted: Fri Oct 27, 2023 5:32 pm
penhosky wrote: Fri Oct 27, 2023 5:01 pm While doing diagnostics on my Panamera I allowed the battery to run down and could not restart it. I used a charger overnight and was able to restart it the next morning but I had two codes go on. One was spoiler failure, which cleared on the second re start. The second one, which doesn’t clear, is “ ACC unavailable.” That’s the Adaptive Cruise Control. Never did it say “ Service needed.” Any thoughts on resetting without a visit to the dealer? Thank you.
Have you tried driving for a distance? It might reset after a few miles, maybe 5 miles or so. If it still doesn't reset, a shutdown, lock, and 30 or so minute wait might work. Several other systems (oil level check, TPMS, red PCM screens, etc.) sometimes respond to a bit of driving followed by a bit of shut down time.
The above is speculation on my part but it's worth a try. It can't hurt.
Posted: Fri Oct 27, 2023 6:24 pm
by penhosky
Thank you. Nothing else needed reset. I did drive two 55 mile trips but continued to show “ ACC not available “ What I haven’t tried is the long shutdown as you suggested, and that’s next. I last drove the car yesterday; will drive again Monday. Will post results. I don’t miss the ACC but I do miss the cruise control.
Posted: Fri Oct 27, 2023 8:07 pm
penhosky wrote: Fri Oct 27, 2023 6:24 pm Thank you. Nothing else needed reset. I did drive two 55 mile trips but continued to show “ ACC not available “ What I haven’t tried is the long shutdown as you suggested, and that’s next. I last drove the car yesterday; will drive again Monday. Will post results. I don’t miss the ACC but I do miss the cruise control.
We have ACC on the Cayenne and never use it. Porsche manages to tie it in to certain options in configs, so it usually worms its way into most builds which results in more electronics that can (and do) get buggy. Plus, alignments are much more expensive even if nothing with the ACC ever goes south.
Hoping it works itself out. If not, maybe it will be a simple fix or reset that the dealer can sort easily. Let us know how it turns out if you can!
Posted: Fri Oct 27, 2023 8:19 pm
Sometimes ACC will be unavailable due to dirt/debris on the cameras. Sounds more like a reset/recalibration thing in light of how it started, but it's not implausible to think the system detected dirty cameras when it rebooted. It's free to check anyway....
Posted: Sat Oct 28, 2023 4:07 am
by penhosky
Thanks; I will do that as well. Next drive on Monday. Having always being a DIY, I hate being a slave to PIWIS. And the electronics seem to have a mind of their own..
Posted: Sat Oct 28, 2023 10:25 am
by signde
blueline wrote: Fri Oct 27, 2023 8:07 pm Plus, alignments are much more expensive even if nothing with the ACC ever goes south.
can you elaborate on what you mean by this?
Posted: Sat Oct 28, 2023 10:43 am
All sensors, cameras and other warning nannys have to be completely re-calibrated with every "regular" alignment. It's involved and costly. Those nannys are inextricably tied to the vehicle's alignment. Cannot correctly or safely do one without the other.
edit: the systems (ACC and alignment) are joined at the hip.
Posted: Sat Oct 28, 2023 10:52 am
by WillyDaP
Absolutely hate ACC, and so glad I did not order on my Cayman GTS!
Posted: Sat Oct 28, 2023 11:03 am
WillyDaP wrote: Sat Oct 28, 2023 10:52 am Absolutely hate ACC, and so glad I did not order on my Cayman GTS!
Agree 100% Bill! Unfortunately, the way Porsche options many of the cars, you have to take ACC if you want certain other desirable options. I have it on the Cayenne and the 992 Turbo S, but not becauseI wanted it on either vehicle.. The configuration game is a bit rigged.
Out the door for the drive to Barber Motorsports Park for a day on track tomorrow! :thumbup: Have a great weekend!
