Door hinges
Posted: Fri Jun 16, 2023 2:35 pm
by blade7
AFAIK the door hinge pin locates in a plastic or nylon bush. Does anyone know the part number, and is it a PITA to remove the old and fit the new bush? Thanks.
Re: Door hinges
Posted: Tue Jun 20, 2023 10:34 am
by 944online
no bushing on 944 door hinges. 911 use a bushing but not 944.
Re: Door hinges
Posted: Tue Jun 20, 2023 3:08 pm
by blade7
How is wear in the hinge repaired then?
Re: Door hinges
Posted: Thu Jun 22, 2023 6:37 am
by 944online
sorry what I meant to say in my last post was that the bushing has never been available as a replacement part from Porsche for the 944. When you purchase a new hinge the bushing is in the new replacement part.
Re: Door hinges
Posted: Thu Jun 22, 2023 6:56 am
by blade7
Understood. Any idea how much Porsche charge for the replacement part, or if something like a brass bush could be made?
Re: Door hinges
Posted: Thu Jun 22, 2023 6:59 am
by 944online
the replacement hinge from Porsche is arouind $60 if I remember correctly. I have seen where others have just made a bushing from brass or bronze. I do not think it would be hard to do but I would not use anything plastic because the doors on 944's are very heavy I doubt the plastic would hold up for very long.
Re: Door hinges
Posted: Thu Jun 22, 2023 8:46 am
by blade7
Brass hinge bushes could be a new part for you. Thank me with a free set :).
Re: Door hinges
Posted: Thu Jun 22, 2023 10:04 am
blade7 wrote: Thu Jun 22, 2023 8:46 am Brass hinge bushes could be a new part for you. Thank me with a free set :).
@TheMadMachinist might be able to make them. :)
Re: Door hinges
Posted: Fri Jun 23, 2023 12:59 pm
by blade7
We're probably an ocean apart. Maybe there's brass tube with the correct o/d, that could be drilled to right i/d.
