I had a chance to test out these new wind diffusers on my 718 Cayman. A father son combo are making what they say are new improved diffusers made of aluminum and seem to be better at high speed compared to the popular AWE foils.
Check out the video for info and install procedure. They are available for the 981 and 718 and soon for the 991 and 992.
Info and How-to: New anti-buffeting wind diffuser for your 981/718/991
- JetFuelOnly
- Has thanked: 35 times
- Been thanked: 75 times
- Larry C
- Has thanked: 451 times
- Been thanked: 486 times
Thanks for the video. Is the installation procedure more difficult if you have lane change assist?
- JetFuelOnly
Can’t say for sure but the triangle should come off the same with enough wiring to have slack. Likely a releasable connector there too! Go give it a try and see what you find. Let us know. It’s easy to check.
With the LCA triangles there's a small connector that is routed up through a small hole in the door panel and plugs into the bottom of the connector.
As mentioned by JetFuelOnly there's plenty of slack to work with, just make sure you don't knock the connector through the hole as you'll have to remove the whole door panel to get the connector back out.
