Trying to rework my vacuum hoses to pass the CA smog visual inspection (tail pipe was fine, but previous owner left very visible vacuum line stubs when removing the cycling valve and adding a manual boost controller + Lindsey DP wastegate).
After I got the intake manifold off, I noticed that the Venturi connection that loops back to the brake booster slides back and forth. That really didn't seem right and my google searches didn't clarify whether that's normal or not. See pics that show in and out positions (finger pointing to the area of interest).
So - is it normal?
If not, what's the best way to resolve it?
(Since I am trying to NOT fail another inspection, removing the Venturi's is not a short term goal).
Thanks!
Vacuum Hose / Sliding Venturi Question
Zirconocene
- Has thanked: 78 times
- Been thanked: 48 times
I don't think that's normal but I also don't have a clear memory of that on my car.
What about just putting a jubilee clamp on the other side?
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
- Has thanked: 947 times
- Been thanked: 4040 times
I don't think it should be loose either, but from memory they are both plastic so you might need rtv or something to seal it? That said, I deleted the venturi on my car over 20 years ago and have never had a smog tech say anything. I used all factory parts made for the '88+ 951, so basically superseded factory parts.
I pulled it out and it just slid out completely. I saw some variations online that have an o-ring, but there's not really a groove on this one for that.
I think I'll just RTV it in place as suggested and go from there.
I will definitely delete it at some point, I just can't take the risk that the next smog visual will look at the vacuum diagram and ask where the venturi is.
- IMG_9571.jpeg (2.33 MiB) Viewed 804 times
1986 951 - Silicon Valley
