Sorry, as a bot-control measure, you need at least one post here before you can download. By asking that question, you now have the required permissions.... If you still have any problems, just let us know.GarethA wrote: Sat Apr 01, 2023 6:36 am Forgive me, please - but how does this website work? ...it says I don't have required permissions.
_____Tom wrote: Sat Apr 01, 2023 7:27 amSorry, as a bot-control measure, you need at least one post here before you can download. By asking that question, you now have the required permissions.... If you still have any problems, just let us know.GarethA wrote: Sat Apr 01, 2023 6:36 am Forgive me, please - but how does this website work? ...it says I don't have required permissions.
True aluminum or stainless would hold up I imagine, but the strength of a 3D printed metal part would be heavily dependent on what machine/process is used. They sell metal-filled plastic for home printers, which would not stand a chance I suspect. On the other hand, there are high-end commercial printers from companies like HP that can print metal that's as strong as the real McCoy. If you send it off to Shapeways or Xometry , etc., and had it done on a million dollar metal printer, I'm sure it would hold up, but that would probably cost a lot more than just buying the tool.rgmarenc wrote: Sun Jul 23, 2023 3:11 pm I might be able to find someone to print this in aluminum or stainless steel. Do you think that would be strong enough? Thanks, Richard
Please report back if it fits. Also, be aware I made this on special request to have a good model of it out there, but a typical 3D printer cannot make one strong enough to torque and untorque the front pully bolt -- it WILL break. It can still be useful to keep the motor from turning while working on belts/cams, etc.shoggr wrote: Thu Aug 03, 2023 4:26 am Hi, this is great! thank you
Does anyone know or confirm if this works with the 968 Tip? I read on other forums it would but not on the manual. Might give it a go.
