Maintenance Time
Posted: Thu Feb 23, 2023 3:28 am
Thought I would post my list of maintenance items I started working on last weekend. This is on my 1986 turbo I acquired in 2015 from the 3rd owner. I had not driven it much since the March 2020 covid lockdown and was building my workshop, too. This is an interesting car as the owner also raced a dedicated 944 turbo in Central Florida and kept this car 100% stock/original. As I have started taking things apart, I am finding almost everything (heat shields, fasteners, etc. ) are there and original. That is in sharp contrast to my first 86 951 that I purchased in 2003. That car was a one owner (by a Dr.) who took it to a variety of garages and was missing heat shields, brackets, some fasteners. I still have that car as well but the timing belt failed in 2016 and is waiting its turn. Still have not decided if I am going to repair the engine but I have resisted any urges to use it for parts.
Here is the list in no particular order:
Thanks,
Lee
- Starter
Timing/balance belts and associated seals
Cam and oil pump seals
Brake hoses and fluid flush
Water pump and all coolant system hoses
Turbo water pump
Motor mounts
Speedometer/odometer
Front struts/rear shocks
Injector cleaning/test
Venturi delete/vacuum lines (yes, it still has hose mess)
Exhaust system
Thanks,
Lee
