3D-Dimple Dies are showing up all over the internet these days, so thought I'd add my own and offer some original shapes. Excuse the video format -- YouTube 'shorts' seem to get more attention....
You can print these in just about any filament -- PLA, ABS, PETG, etc. -- just crank up the infill to 75% or so. No support needed. They work over and over and have been tested on steel up to 18 gauge (22 gauge shown in pictures).
These are all set up for a 1 inch hole, but virtually all slicers will let you scale to whatever size you need. For example, if you need a 1.5 inch hole, just scale it to 150%. A 20mm hole would be 20/25.4 = ~79%, etc. Just be sure to use "uniform" scaling or otherwise make sure at least the x and y axes are scaled the same. (You can play with the z axis if you want to adjust the depth).
3D-Printed Dimple Dies
- Has thanked: 498 times
- Been thanked: 2337 times
You need at least one post on Carpokes to see and download files.
Now that you posted this, they should be available at the bottom of the first post.
- Has thanked: 1 time
Thanks for posting these!
