Re: Switch to shut-off PSE....
Posted: Mon Aug 14, 2023 3:40 pm
Yes. Up until the 992, all you need to do to make it loud 100% of the time is pull the electrical connector off the solenoid. With the 992, they changed the system to trigger a CEL if the servo position doesn't move to where the ECU wants it.Arne2 wrote: Mon Aug 14, 2023 2:21 pmSo if I install a used PSE system, with the factory solenoid, but don't send it any power, the flaps will be always open? That could be a good stop-gap or interim solution, given that the the 4-cyl PSE is not supposed to be all that loud. Probably still quieter than most aftermarket exhausts.Tom wrote: Wed Jun 21, 2023 7:02 pm ...you'd need at least the exhaust with vacuum operated PSE flaps and the electronic solenoid that controls them, plus the vacuum hoses. Normally, an ECU controls the solenoid based (mostly) on the position of the switch inside, but a simple switch similar (but not identical) to the one in this thread could/would substitute for the ECU. Always Loud is super easy because the flaps open when power is cut to the solenoid.
