This thread has been great to follow. Especially since I know nothing of 911 engines/trans.
You do amazing work my friend!
When Spring Routine Maintenance Turns in to something.
- Has thanked: 962 times
- Been thanked: 4161 times
Agreed, so inspiring!PSU_Crash wrote: Mon Jun 15, 2026 6:30 pm This thread has been great to follow. Especially since I know nothing of 911 engines/trans.
Here are some picture during the completion of the engine.
Cam timing is done, and the chain tensioner istalled.
Continuing assembly.
I'm using silicon gaskets for the valve cover.
The fan and housing was powder coated over 10 years ago. Good to see it holds up nice.
More assembly
More to come.
Engelbert
More assembly
More to come.
Engelbert
- Has thanked: 4606 times
- Been thanked: 2499 times
I'm out of adjectives Engelbert so I'll just use a good old standby: Awesome!!
It looks as good as or better than one from the factory back in the day.
octane1749
- Has thanked: 1 time
Thanks for all the detail and pictures.
Just curious, but how many hours did the whole process take? (asking about your time in garage--not downtime for any outsourcing)
- J-Dub
- Has thanked: 669 times
- Been thanked: 584 times
Last weekend I took my 2276CC aircooled 4 cylinder apart for a camshaft swap. I was hoping for a simple in and out, maybe a quick hone on the cylinders to break the glaze and put it back together. I unfortunately the center split main bearing was starting to show copper. Dang.
Broke it the rest of the way down and took the case the shop for a professional assessment.
1957 VW Beetle
2004 VW R32
2021 Porsche Cayman GTS 4.0
2004 VW R32
I'm sure it's over 250. Most of the time was spent for cleaning, cleaning and cleaning again, LOL.octane1749 wrote: Thu Jul 09, 2026 6:59 pm Thanks for all the detail and pictures.
The engine and transmission is back in the car.
Here are a few pictures.
Ready to install.
Hanging in there.
When I tried to hook up the clutch cable it just broke at the thread where the two adjustment nuts are. OK, I need a new one. So I started to disconnect the cable at the pedal cluster, and found that also needs an little work. The good thing was that all the interior bits and pieces were already removed, because I had to install a new wiring harness for the power seats and seat heater.
The good thing was that I had a new shaft and all new brass bushings set in my spare box.
I blasted and powder coated the base and installed everything.
Also the new to the car power seats are installed and all is working.
I already made about 130 miles on the fresh engine. Still need a few adjustments to CIS.
Engelbert
Ready to install.
Hanging in there.
Engelbert
octane1749
Wow!! Thanks for the pictures and information!!Carmagic wrote: Sun Jul 19, 2026 10:26 amI'm sure it's over 250. Most of the time was spent for cleaning, cleaning and cleaning again, LOL.octane1749 wrote: Thu Jul 09, 2026 6:59 pm Thanks for all the detail and pictures.
