951 Resurrection - after 7 years of storage
fasterfaster
Has thanked: 164 times
Been thanked: 22 times
Meine44 wrote: Sun Mar 29, 2026 2:54 pm I received the new gauge for the coolant vacuum tool, and tested it on the car today. It will get to 15 in-Hg of vacuum pressure before coolant starts coming out of the venturi hose.
I left the system under 15 in-Hg of vacuum pressure for 10 minutes and the pressure didn't bleed off, so the system must be sealed. This gives me a fair bit of confidence that there are no leaks on the system. I will plan to bleed the system at the vent and top off with distilled water as needed before driving the car home from storage.
Like I was asking earlier, I think you may be mixing up some of your terms and measurements. Vacuum is the opposite of pressure. So are you sure you are pulling a vacuum, aka putting the system under negative pressure? In that case, you are not actually testing your coolant system properly. It needs to be under positive pressure, NOT a vacuum. However, any coolant test tool I'm aware of creates positive pressure, so I suspect you're just misusing the term "vacuum."
Also, 15 in-Hg is only about 7psi. If you ARE in fact pressurizing the system, then this is only about half of the pressure it needs to take. You need to pressurize it to 15psi/30in-hg (which is what your OE coolant blowoff cap should be). If you are experiencing leaks at 7psi/15in-hg (again, of *positive* pressure) then that is your problem - it will leak under normal operating coolant system pressures.
Marc
88.5 951 M030 Red on Black
#21
Meine44
Been thanked: 6 times
fasterfaster wrote: Sun Mar 29, 2026 9:10 pm
The tool I have is a vacuum tool; it is also used to fill the system with coolant under vacuum to eliminate air pockets in the system. The idea is to fill the system under vacuum instead of bleeding the system at the bleeder screw. Usually I do both: fill with the vacuum tool, THEN bleed the system at the bleeder screw.
The vacuum system can check for leaks, but it is more difficult to spot them with soapy water. The bubbles that show near a leak under vacuum are more difficult to spot than when the system is under positive pressure, but not impossible. The system should still hold a vacuum the same way it would hold positive pressure.
I think the major difference is that the system will NOT hold vacuum while the vacuum pump is still running because it is sending coolant out of the venturi hose. Once the valve is closed it holds vacuum, but won't build past 15 in-Hg once the coolant starts evacuating.
#22
fasterfaster
Ah, got it. You're using a vacuum bleeder AS your leak tester. Certainly a failed vacuum will also highlight a leak, but it is a different failure mode than a positive pressure leak. Not to mentioned harder to track down. It is entirely possible to have a system fully sealed under vacuum (which increases hose clamp/seal pressure) and still have leaks under positive pressure.
If you're still losing coolant after your next fill, I recommend dropping the $30 on a pressure testing kit.
Marc
#23
Meine44
I haven't been able to spend much time on the car lately due to my work schedule.
However, I did find a used coolant reservoir at a price that I couldn't pass up, and it was worth every penny!
Now the coolant level is clearly visible; no more guess work.
I will still bleed the system through the vent bolt and cycle the HVAC system to get air out of the heat exchanger etc. I do plan to invest in a pressure tester also at some point.
danmartinic
Has thanked: 23 times
Been thanked: 39 times
What are you pointing at?
#25
Meine44
danmartinic wrote: Wed Apr 15, 2026 1:24 pm What are you pointing at?
When I removed the coolant reservoir, I found a loose bolt in the engine bay. I don't know where it came from or how long it's been rattling around in there.
Hopefully it's not for something important. :think:
danmartinic
I'm game
One of the bolts that attached the original AFM to the original air cleaner housing
#27
Cruise98
Has thanked: 16 times
Been thanked: 23 times
My guess is one of the bolts for the water pump. If we win, do we get your old coolant tank as a prize?!
#28
papamurphdog
I have owned and worked on two 951's and you should NOT start the thing and first do all the maintenance; all the fluids, all the hoses, all the danged vacuum lines, all the belts, the timing belt pully and tensioner, R&R the water pump and gasket while you are in there, remove the MAF and clean it, remove the furl rail and clean it, remove the injectors and clean them and replace seals. Now, about that "melty" harness, get a new one from Gary Beussink or 944.online. com or somewhere. The issue of a "no start" is because the injector connectors are hard and brittle (and likely permanently kinked) and the the wires inside on one of them are touching each other and shorting out occasionally (usually after getting warm), once fixed, not more no-start. Before you do that remove the intake and clean that and replace the gasket. R&R the turbo and inspect to see it's all good. Clean and reinstall. New plugs. Top end done.
Do the chassis next: R&R the wheel bearings (repack is easy), add stainless brake lines on all 4 corners, redo the seals on all the calipers (stopping is good to have), transaxle seals/boots (both sides) [new TAs all done are kinda cheap, I'd do that], ball joints on the front (shocks all around?), tires are OLD AS fudge (get new ones for sure), anything rubber, change it to new. Clean steering rack and inspect boots. Check the intercooler hoses and clean it. Flush it out even better. Check the rad hoses and flush. New expansion tank is cheap.
That's my list based on what you said in your post...
#29
Meine44
The car has been relocated from offsite storage to the home garage. No leaks to report, oil level and color looks OK, coolant looks OK. All fluids are on the short list to be flushed.
The car would not start without a jump from another vehicle, even after the battery was stored on a trickle charger. I have no dash lights, and no warning lights seem to be operable except for the central "!".
Fuel gauge, oil pressure, voltage, and tach are working. Speedometer, odometer, and temperature gauge all not working. Maybe caused by a weak battery or loose connections behind the dash. The gauge cluster will get sent out for repair as mentioned earlier.
Happy to have the car home and accessible for refurbishment. Something about the driving feel of the car and the noise it makes brought me a great joy that I haven't experienced in the last few years on two wheels. Motorcycles are fun, but nothing matches the character of a 951!
#30
