DME Frame - Plastic fastener Part #
- Latitude48
- Has thanked: 105 times
- Been thanked: 113 times
On a related note. Can anyone confirm exactly how the DME is mounted to the metal frame? When I just pulled my DME to install the F9T DME w/OBD+ my DME was only attached with one speed nut and screw, plus one other screw that also secured the bracket for the alarm. The PET shows there should be four speed nuts and screws. I know the DME has been pulled a couple of times to change chips when my son had the car, so I suspect it never got put back together correctly. Thanks for any info. BTW, I'm also going to order these plastic push buttons, as Porsche calls them, just in case I ever lose or damage one.
Tom Pultz
- Doyle623
- Has thanked: 13 times
- Been thanked: 7 times
Here is a pic I took of a virgin DME/KLR, mounted into their frame.
1986 944 Turbo - Vitesse MAF (Stealth), Evergreen K27/8 Raptor, Kroon, Ftech9, KW V3, etc.
2005 911 Carrera S Launch Edition
- Has thanked: 945 times
- Been thanked: 4040 times
I always wondered why they made the harness so long under there, especially the KLR harness that seems to be a foot longer than needed..... It's like they know people would drive around with those boxes sitting where your feet should be....Doyle623 wrote: Fri Jul 29, 2022 2:31 pm Here is a pic I took of a virgin DME/KLR, mounted into their frame.
- Doyle623
I agree...then add in piggyback wiring, etc, and it becomes real fun to jam in there!
- Darwin
- Has thanked: 116 times
- Been thanked: 74 times
Going standalone really reduces the amount of congestion there!
2012 VW Tiguan - Kinda stock
- Latitude48
It clearly falls into the 2S category as it has both "masculine and feminine spirit."Tom wrote: Tue Jun 14, 2022 10:07 pmI think the gender terminology is causing issues with this part. It's not clearly one or the other I'd say....Latitude48 wrote: Tue Jun 14, 2022 4:18 pm Isn't the OP looking for item #33, which is the female piece (sleeve) requested? #32 appears to be a male push-pin. #33 is 944 551 437 00.![]()
Tom Pultz
