Door handles out while charging on 992
elm310
Has thanked: 271 times
Been thanked: 92 times
Hi All,
So I finally connected my battery charging my 992 GTS, I left the frunk semi-closed, not completely closed. And I noticed while charging, the door handles stay "out" while it is charging. Is that ok? Keys are not near the car. Is it because the frunk is still open?
Eric
2022 911 Carrera 4 GTS
2009 BMW e92 M3
2014 BMW f10 535i
2017 Nissan Frontier SV
2019 Yamaha AR210 Jetboat
Hawk
Has thanked: 131 times
Been thanked: 116 times
elm310 wrote: Fri Jun 10, 2022 12:26 pm Hi All,
Eric
If you run your maintainer wire out of the gap in the frunk by the windshield (close to the fender) you can close the frunk lid completely. Then you can lock the car. That will also put the car's various systems to sleep over time. That is the procedure I used with my 992 Carrera.
Dick
elm310
Hawk wrote: Fri Jun 10, 2022 12:52 pm
Eric
@Hawk I just afraid that the positive alligator clip will contact the frunk. That is the only reason that I left it semi-open. It is weird on how to clip the alligator connectors. Not much room on the positive side of the battery.
Eric
2009 BMW e92 M3
2014 BMW f10 535i
Hawk
elm310 wrote: Fri Jun 10, 2022 1:02 pm
Eric
Eric
I did not experience that issue as I didn't use or try the alligator clips. I used a hard wire connection / extension off the battery and ground that I ran into the frunk and simply would plug into.
Dick
Hawk
@elm310 What type of battery are they using in the GTS? Is it the LiFePO4 or AGM?
Dick
Has thanked: 935 times
Been thanked: 4006 times
I've charged mine without the door handles sticking out. I have the lithium battery and, from memory, the alligator clips things weren't close to the hood, so I did shut it that way (though now I'm wondering if I just overlooked that risk?). I'm guessing your door handles stayed up because the frunk wasn't fully latched...
elm310
Hawk wrote: Fri Jun 10, 2022 1:52 pm @elm310 What type of battery are they using in the GTS? Is it the LiFePO4 or AGM?
@Hawk the dealership told me that I have the AGM battery, not the Li.
Eric
2009 BMW e92 M3
2014 BMW f10 535i
elm310
Tom wrote: Fri Jun 10, 2022 3:02 pm I've charged mine without the door handles sticking out. I have the lithium battery and, from memory, the alligator clips things weren't close to the hood, so I did shut it that way (though now I'm wondering if I just overlooked that risk?). I'm guessing your door handles stayed up because the frunk wasn't fully latched...
I'm going to look again, I might have space also and will shut the frunk completely. That should take care of the door handles.
Eric
2009 BMW e92 M3
2014 BMW f10 535i
elm310
@Tom and @Hawk it's all good. Did have enough room between clips and frunk, so I went ahead and fully closed the frunk and in a few seconds the door handles retracted to closed or normal mode. Thank you both.
Eric
2009 BMW e92 M3
2014 BMW f10 535i
