Hey all,
I will be fitting some new castor blocks this week and whilst they are pretty simple to fit I couldn't see any information on whether you can just raise the front up and unbolt them. Do the arms need to be under load with wheels on the ground or can they be hanging freely?
Thanks
Castor block fitting
Before swapping, measure your caster.
Then raise the car and swap the caster blocks with the wheels hanging. Torque the bolts mounting the caster blocks to the chassis, but not the nuts on the eccentric cranks.
Put the car on the ground and adjust the eccentric cranks to get back to the caster measured at the start. Then torque the eccentric crank nuts.
'87 944 NA
Great thanksjeyjey wrote: Tue Jun 30, 2026 12:13 pm Before swapping, measure your caster.
chrischrischris
- Has thanked: 7 times
- Been thanked: 45 times
Did you use the 968 Castor blocks? Did you re-use the original eccentric bolt or source the 968 version?
Yes the 968 version. I reused my eccentric bolt as it was in good condition and relatively no difference.chrischrischris wrote: Mon Jul 13, 2026 8:34 am Did you use the 968 Castor blocks? Did you re-use the original eccentric bolt or source the 968 version?
chrischrischris
That's good to hear. The 968 eccentric is a bit expensive.
- Latitude48
- Has thanked: 108 times
- Been thanked: 126 times
Four years ago I paid $110.54 each for 951-341-431-03 control arm eccentric. They are now around $134 ish. The same P/N is listed in the 968 and 944 PET. The latest 03 version has serrations so they hold the setting better. The newest version also has a hole in the adjuster for identification. [not my image]chrischrischris wrote: Mon Jul 13, 2026 1:21 pm That's good to hear. The 968 eccentric is a bit expensive.
- 951_caster_eccentrics.jpg (91.33 KiB) Viewed 204 times
Tom Pultz
That's interesting to know thanks.Latitude48 wrote: Tue Jul 28, 2026 2:06 pmFour years ago I paid $110.54 each for 951-341-431-03 control arm eccentric. They are now around $134 ish. The same P/N is listed in the 968 and 944 PET. The latest 03 version has serrations so they hold the setting better. The newest version also has a hole in the adjuster for identification.chrischrischris wrote: Mon Jul 13, 2026 1:21 pm That's good to hear. The 968 eccentric is a bit expensive.
