Alusil Pistons
gruhsy
Has thanked: 48 times
Been thanked: 81 times
Anyone know what the latest news/ situation is with Wossner Pistons and stock Alusil bores…..Brand new block from Porsche
Mahle only have 100.5mm and 101mm unless anyone knows differently
Thanks
Has thanked: 949 times
Been thanked: 4047 times
Putting aside whether they (or anyone else) can make a gall-free piston for Alusil these days, I don't think there is much of a market for standard size pistons unfortunately. They list .5mm overs, but STD say sold out. Love the block though. Maybe custom order from Mahle?
Latitude48
Has thanked: 105 times
Been thanked: 114 times
It seems that unless you get something custom you may need to get that brand new block enlarged for the 1st oversize. As i recall @four0four who is also a WA resident, had his done down in Oregon. It sure does look pretty though.
Tom Pultz
Bergerac
Has thanked: 20 times
Been thanked: 126 times
Have you measured your bores? My new 968 block from Porsche was delivered 0.5mm oversize.
Bergerac wrote: Mon Jun 29, 2026 7:35 pm Have you measured your bores? My new 968 block from Porsche was delivered 0.5mm oversize.
Wow, really? Brand new from Porsche?
four0four
Has thanked: 22 times
Been thanked: 32 times
Latitude48 wrote: Mon Jun 29, 2026 7:27 pm It seems that unless you get something custom you may need to get that brand new block enlarged for the 1st oversize. As i recall @four0four who is also a WA resident, had his done down in Oregon. It sure does look pretty though.
True, but unfortunately I learned here that they've since closed up shop :(
Bergerac
Tom wrote: Mon Jun 29, 2026 8:18 pm
No I was confused, just checked my build sheet from mahle and the bores were 4.095", I think I mixed up the tolerance groups with oversized.
The tolerance group is stamped on the block face on each cylinder near the oil passages, you can see it in the pictures above.
Looks like yours is 1 as well so 100.0 pistons would be slightly small
gruhsy
I will check the block for bore size
Thanks for the heads up.
The block belongs to Soloracer
I’m putting it together for him
I’m thinking it might be wise to put Porsche pistons in it. Can’t go wrong with that even though more expensive.
Probably Molnar rods
The block was the last one in Canada sitting in Toronto
