Balance shaft belt tensioning
Real-Time Help, 24/7 — Tuned with Curated Porsche Knowledge
PSU_Crash
Has thanked: 192 times
Been thanked: 113 times
Tom wrote: Sat Jun 20, 2026 4:23 pm I need to get the digital tool done...
I agree! 😁
On topic, I did the 90° method with my balance belt and I thought it whined a bit much. Now with aprox 2k miles on it, I rechecked. It only went slightly past the 90° mark with "roughly" the same finger pressure. The whine is less, although still present. At this point I think they all whine to some extent.
BennSport
Has thanked: 7 times
Been thanked: 30 times
PSU_Crash wrote: Sat Jun 20, 2026 7:48 pm
I agree! 😁
Mine whines on startup in first gear, but goes away after a couple of minutes. Other forums were suggesting ~135 degrees of twist, which seems quite loose to me. But then again, I’d rather it be too loose than too tight.
‘83 Platinum N/A 944
BennSport
Tom wrote: Sat Jun 20, 2026 4:23 pm I need to get the digital tool done…
Im on the edge of my seat waiting for it! Will you be able to use it on the balance belt as well?
NC944er
Has thanked: 4 times
Been thanked: 20 times
When both the camshaft timing and balance shaft belts are set correctly using a deflection gauge, the balance shaft belt runs noticeably looser than the timing belt. For what it’s worth, the same finger/thumb pressure used to twist the timing belt to 90° will generally twist the balance shaft belt a bit beyond 90°, I’d estimate between 110-120°.
As others have said, this method is subjective and better used as a sanity check to ensure the gauge isn’t way out of calibration or placed incorrectly when taking a measurement. Of the 944s I’ve serviced, about half of them come in with the balance shaft belt over tensioned.
danmartinic
Has thanked: 26 times
Been thanked: 43 times
PSU_Crash wrote: Sat Jun 20, 2026 7:48 pm At this point I think they all whine to some extent.
Absolutley not. Drive the car regularly for a while, like a month or two daily
Your whine will disappear 👍
CEW
Has thanked: 5 times
Been thanked: 24 times
I normally adjust and shoot for “just barely noticeable” whine on a new B/S belt. Loud whine=too tight, no whine=too loose.
PSU_Crash
danmartinic wrote: Sun Jun 21, 2026 5:21 pm
I'd love to DD the ol girl, but the weather has been less than agreeable. I'm at about 2k miles over a year since the change. Seems mine may still be a bit too tight. I'll get back in there soon
